It is currently 19 Jun 2013, 10:45
Post new topic Reply to topic  [ 34 posts ]  Go to page 1, 2, 3, 4  Next
 Post subject: Motion Tools
PostPosted: 01 Mar 2012, 15:44
Motion Tools is a set of ICE Compounds and Python Scripts that aims at aiding the Motion Graphics workflow inside Softimage.
This was previously posted in the community project thread, but since I'm making an Package Addon with some scripts and such I thought it needed a place here.
v0.2 Highlights:
All features found in moGraph cloners are present here (plus some more)
Better workflow through menus
For a better understanding of what the tool is and how it works, please visit the old video: https://vimeo.com/32825206
Full Release Notes:
http://dl.dropbox.com/u/39280733/MotionTools/v0.2/ReleaseNotes.txt
Addon:
http://dl.dropbox.com/u/39280733/MotionTools/v0.2/MotionTools.xsiaddon
(note that you might have to restart the software, after install, for things to work properfly)
If you get to use it, please, send a postcard and report some bugs :)
Gustavo Eggert Boehs
 Post subject: Re: Motion Tools
PostPosted: 01 Mar 2012, 18:05
Your link to the "Full Release Notes" point to the same download address as the one for the addon...
PostPosted: 01 Mar 2012, 19:04
fixed, thanks :)
PostPosted: 04 Mar 2012, 18:09
Thanks for sharing this!
www.coroflot.com/SreckoM
PostPosted: 06 Mar 2012, 20:15
Gustavo, the video looks great, thanks!
But: I'm not seeing those menu-entries you've got in ICE > particles > create. I see the addon installed correctly in the pluginmanager, and I also see the compounds in my ICE preset manager. Is there some other stuff that needs to be installed in order to have it work correctly?
(2012 SAP)
thanks, Jasper
PostPosted: 06 Mar 2012, 21:55
Hi Jasper, thanks for download and reporting problems. :ymhug:
I had this happend to me also... In my case it was related to the Python installation, it so happends that when you uninstall one old version of Softimage, Python vanishes from the remaining verions also. Just check the available scripting languages in your installation (see attached image). If Python is not then run "runonce.bat" (for more info http://xsisupport.wordpress.com/2010/06/28/python-not-available-in-2011-sp1-after-you-uninstall-2011/).
Hope this helps :)
PostPosted: 07 Mar 2012, 14:02
Hi Gustavo,
thanks, that was it - must've uninstalled older version recently.
Testing now, a few questions:
I notice that although 'create Instance Array on geom' works, whenever I try 'create Instance Array' I get this error message:
Code:
'   File "<Script Block 2>", line 42, in ICEFlow_CreateInstanceArray
'     if oTmp == "Linear": ICEFlow_CreateInstanceArray_Execute(0)
'   File "<Script Block 2>", line 93, in ICEFlow_CreateInstanceArray_Execute
'     MTools_ApplyInstancer(oPC, oObj, type, oGeo)
' UnboundLocalError: local variable 'oPC' referenced before assignment
'  - [line 92 in G:\Workgroup\Addons\MotionTools\Application\Plugins\mTools_ICEFlow_Plugin.py]
In 'Array on geom', going to voxels mode, it's easy to pull the resolution slider down to '0' where SI will hang/freeze for some minutes, then come back but without voxels working. After a few times going back and forth between modes, voxels come back. Possible to prevent the slider from going to zero?
Is it also maybe an idea to have 'voxels' mode automatically switch to 'shape' because it seems it doesn't work with 'instance shape'?
In the particles>create menu, is it possible to have a divider/header 'MotionTools', thinking ahead for when there will be tens of menu items added by various plugins and it becomes hard to discern what is what.
thanks, Jasper
PostPosted: 07 Mar 2012, 19:20
Hey Jasper,
Ill take a look on what is producing those errors... I already have an idea, but it should not be hard to get rid of this.
On the resolution thing, it is possible to prevent it from evaluating 0 easily. But I was thinking it might be even best to just inver the behaviour of this, so the resolution number grows we have more instances. I implemented it as is right now to make it work like Lagoas resolution, but giving it more thought I guess the other way around might be more intuitive, and prevent freezing at the same time. What do you think?
Voxels do work with instanced shapes here, is it not working for you for some reason?
I'd love to create a Motion Tools header, my Python/SDK skills are still limited, as they grow, I hope to be able to achieve this...
Again, thank you very much for taking the time and testing this...
PostPosted: 08 Mar 2012, 15:24
Hi Gustavo,
voxels do work now with instanced shapes, don't know why they didn't yesterday. Create Instance Array still gives the same error.
Inverting the resolution behavior sounds like a good idea, it solves the problem in an elegant way. Although I don't have intuitive problems with the way it is now.
On the matter of intuition: I think the picking order is counterintuitive, I keep on expecting that I first pick the object that I want to be instanced and then the object that I want it to be instanced on. It's more in line with 'instance array on geom' too; first 'instance', then 'array on geom'. Or is my thinking twisted? :)
Is it possible to include a 'hide instance master' button in the compound? Going through the object's visibility options, making a local copy and ticking the box there on and off if you want to switch is tiresome and confusing if you're dealing with multiple instance masters.
'Ramdones' parameter is randomness? Is it applying a random seed to how to pick items from a group? Is it possible to add a string input box, so that you can choose the items with more control (as in the scatter compounds, '0,1,1' gives twice as many items 1 to 0)
And a randomize slider for 'scale' too?
(btw, I think/ am quite sure I'd be able to add those last two myself in ICE, but I think these are some basic features to make the compound more useful.)
Thanks, Jasper
PostPosted: 08 Mar 2012, 17:28
You have a point :)
At the moment buttons are not possible in ICE PPGs, on the other hand a less intuitive checkerbox can be done... Good suggestion
Another good one for the todo list
This can be already achieve through the modifier Randomize, it also randomizes rotations, position and colors with intuitive controls... :)
