It is currently 21 May 2013, 18:20
Post new topic Reply to topic  [ 10 posts ]
 Post subject: script about Schematic.
PostPosted: 15 Feb 2012, 16:07
Hi!
Since English is very poor, it is difficult to tell, please answer.
There is a question about "Schematic" newly supported by softimage2012.
Using this command, it is trying to make the script which arranges a node in the specified position.
Although the position information on each node has acquired the sample etc. to reference now, the method of going to set position information is not known.
how should it describe?
Currently, the position of the node was able to acquire.
※It has seldom changed from the sample.
Code:
from siutils import *
viewname = 'MySchematic'
desktop = Application.Desktop;
activelayout = desktop.ActiveLayout
v = activelayout.FindView( viewname )
if v == None:
   log('Creating new schematic...: %s' % (viewname))
   v = activelayout.CreateView( "Schematic", viewname )
sv = disp(v)
for node in sv.Nodes:
   (x,y,w,h) = node.UIInfo
   log( 'name=%s x=%d y=%d w=%d h=%d ' % (node.Name,x,y,w,h,) )
File comment: Complete image
 Post subject: Re: script about Schematic.
PostPosted: 17 Feb 2012, 13:48
You're going to have to get into some fun math logic for that. Here is a simple plugin that expands / collapses nodes from their average position. Take a look at the code (not the prettiest I've done but gets the job done).
One down side is that you have to recurse all of the nodes under the selected ones to move them. This implementation only does the selected nodes and their direct children. Will look into it but I might have to put in a request for an additional argument that moves all child nodes with the .move() method.
Check it out and the code in it as well which will hopefully point you in the right direction.
http://www.ethivierge.com/et-schematictools/
Eric Thivierge
ethivierge@gmail.com
http://www.exocortex.com/products/species/
PostPosted: 18 Feb 2012, 16:56
<EricTRocks
Thank you for your reply!
I investigate mathematical logic.
sorry.
The link has run out.
Would you teach the link place once again?
PostPosted: 18 Feb 2012, 17:18
The link doesn't work for me either... (@EricTRocks - the "same old" problem, again?)
Broken, not stirred...
PostPosted: 19 Feb 2012, 00:40
See attached file. I really do need to figure this out. @take_tommy, what country are you in that can't access that page?
ET_SchematicTools.zip [1.09 KiB]
Downloaded 23 times
Eric Thivierge
PostPosted: 19 Feb 2012, 11:23
I've tried to access my site from a proxy in the netherlands and get to the pages just fine. What happens when you go to the link? Just a dead page or a page not found?
Eric Thivierge
PostPosted: 19 Feb 2012, 12:59
Yes, from a proxy it works just fine here too... Why? No idea. Part of your website is accessible normally, part of your website throws a "Not found - Sorry, but you are looking for something that isn't here." So something weird is going on. Especially considering that I just tried http://www.ethivierge.com/animstore/, that didn't work a few weeks back and now strangely loads like it should have originally.
Could it have something to do with your Wordpress blog handles new pages? Maybe it only affects the most current page? (Just guessing, BTW)
PostPosted: 19 Feb 2012, 13:07
Hmm not sure. Wonder if it is a caching issue somewhere along the line. I'll check and see if wordpress caches my pages. Can you try to shift+reload on the page that isn't currently loading to check if its a browser issue (just throwing it out there...).
Eric Thivierge
PostPosted: 19 Feb 2012, 13:18
Sadly, no: reloading the page doesn't change the result.
And it doesn't seem browser-specific either (I just tested with IE, FF, Chr & Opera)...
PostPosted: 19 Feb 2012, 17:24
@EricTRocks
Thank you for the file.
>what country
I live in Japan.
Currently, the link is visible without any problems.
