It is currently 23 May 2013, 05:05
Post new topic Reply to topic  [ 45 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
 Post subject: Re: End of the World.
PostPosted: 06 Feb 2012, 18:29
Hi!
Did you thought of using the grid render option of the BA_shaders..? Right now you are rendering just particles and this always leads to the same problems...flickering, noise etc..
I think Eric gives some shading exapmles in his actual version of emfluid4. Though, to get nice results, the grid of the fluid must be quite hires...
Here are some test on this:
..and even Holger talking about his shaders at the UeberTage meeting 2011 (German though..)
cheers,
oli
http://www.pixelpanic.de
http://www.softimage-uebertage.de - international SOFTIMAGE Usermeeting 2012
PostPosted: 07 Feb 2012, 05:05
Thank you Oliver.
http://www.behance.net/MasterMason
PostPosted: 07 Feb 2012, 09:36
Hi!
Sorry, I just saw' hat you are using the Fluid shaders already...just saw your tree at the first image...well, to improve this, you may work in the alpha and color gradients you are using. The fractal also seems quite noisy. Difficult to tell...
PostPosted: 07 Feb 2012, 15:11
Oliver, how can be activated grid render option ba shader? where is it? indeed there are some problems, flickering, noise. Now I learn into the ba_shader never used before. Sorry for spelling and other errors.
PostPosted: 07 Feb 2012, 23:31
Hi!
Well, I can´t read your tree you posted on the first page good enough, but I think, you already us the BA_fluid node wich does exactly that. I can´t see if you are getting the scalar value out of emFluid (via BA_fluid_value_float) and pipe into the BA_fluid node. As I said, have a look at the examples Eric provides in the samples..
The flickering may be caused by other settings though...but the grid stuff mostly works quite flicker free..
cheers,
oli
PostPosted: 11 Feb 2012, 09:19
I do not know.
PostPosted: 12 Feb 2012, 13:53
The Second.
PostPosted: 13 Feb 2012, 14:13
the wave comes to late, your mushroom is growing but your wave comes after this.
this video shows it really good what happened and what you should change.
http://www.youtube.com/watch?v=Z24nVmGL_r4
also, i am not sure about the speed, i think its to uniform compared to different clips of abomb explosions i watched.
PostPosted: 14 Feb 2012, 01:05
Imimprovers on it, but now the city made it. I'm to drop bomb on the city. :D
Momentum 3 and voronoi fractal, will be amazing. =p~
PostPosted: 14 Feb 2012, 16:16
Hi Mason,
Interesting thread. Definitely wanna see how we all cease to exist. Until than though, would you mind sharing some info on how you made the city? ;) Thanks
