It is currently 20 Jun 2013, 05:38
Post new topic Reply to topic  [ 101 posts ]  Go to page Previous  1 ... 5, 6, 7, 8, 9, 10, 11  Next
 Post subject: Re: quickinset
PostPosted: 02 Feb 2012, 11:43
Great to see it finished!
Congratulations on a brilliant tool and thank you very much for releasing it Piotrek.
PostPosted: 02 Feb 2012, 13:50
bottleofram wrote:
Great stuff as always, piotrek. :ymapplause:
Don't know if this has been discussed already, but would it be possible to implement some of the advanced selection characteristics into the tool? For example, edge loop selection on double click and shortest path selection. That would useful when beveling the edges interactively. Right now it seems you can only select the edge one by one...
yep you can only select subcomponents one by one.
I was thinking about adding those,
but then again if you work with tool in sticky mode, you can always turn on selection tools in supra mode to select some stuff.
PostPosted: 02 Feb 2012, 14:30
Oh, I see. That'll work!
Hopefully you receive enough requests to eventually implement it (for the sake of convenience), but the tool is an immense improvement for the workflow as it is, nonetheless. Thanks
PostPosted: 02 Feb 2012, 14:46
for a reason i can't find i can't make it work..
after installation:
-i go to the plugin manager>pmQuickExtrude(addon)>Plugins and the icon before the name of the tool has a red triangle.
-also i noticed after the icon, it writes pmQuickExtrude.dll shouldn't it write the name of the plugin?.
when i right click on the pmQuickExtrude.dll and choose properties i get a message : library not found" with the instalation path..
any idea what might be wrong?
si2012, win7/64bit
ps: the previous edition of the tool (the quick inset one) worked fine..
PostPosted: 02 Feb 2012, 15:15
Hi, red triangle means for some reason dll was not loaded.
I compiled the x64 bin against 2012 SAP libraries.
Probably I should link with 2012 libs...anyone with 2012 non-SAP x64 can confirm it's not working?
PostPosted: 02 Feb 2012, 15:21
Working fine here. SI SP1 64bit, win 7.
Testing ground. What a nice, powerful tool.
PostPosted: 02 Feb 2012, 15:37
Thanks memag
well due to my limited knowledge of c++ voodoo I can recommend only installing vs2010 redist. http://www.microsoft.com/download/en/details.aspx?id=14632
PostPosted: 02 Feb 2012, 15:40
thanks, I'll try it!
YES, PROBLEM SOLVED :ymapplause:
Thanks a lot origin, both for the solution and the great tool!
PostPosted: 02 Feb 2012, 16:58
This tool ROCKS!!! Great work!!! :-bd
Is there some trick to getting this to work with keyboard mapping? I mapped it and it does nothing... :-s
PostPosted: 03 Feb 2012, 09:29
Just WOW! This is one amazing tool. Feels so organic and intuitive. Hats off and thank you for sharing it.
