It is currently 18 May 2013, 12:20
Post new topic Reply to topic  [ 14 posts ]  Go to page 1, 2  Next
 Post subject: ICE - Modulo trick and variants
PostPosted: 17 Oct 2011, 01:33
I was made aware a while ago of the modulo trick to replace loop and counters. The first time was back in May when Stephen Blair poster a screen grab of the modulo trick on XSI Support Blog to generate a better duplicator (screen below).
Then this month Chris_TC posted a variation of the modulo trick on XSI Base to generate an array of points in x and z (screen below as well).
During my experiment with the Bezier surfaces, I used the modulo trick to generate numbers in u and v. The trick was very much similar to Chris_TC.
The modulo trick is still talked about, even on XSI List and I wanted to share some screen of my own to contribute to the conversation about the usefullness of this trick.
 Post subject: Re: ICE - Modulo trick and variants
PostPosted: 17 Oct 2011, 01:44
The first thing we notice between Stephen Blair and Chris_TC is Chris is using the build index array node and Stephen is using the build array from constant + get array sub indices combination to feed to the modulo. If you open the build index array compound you will notice that the two nodes that Stephen uses are the build index array. Technically, Chris and Stephen are using the same compounds. Good, to simplify then we will use the build index array.
So, the basic Modulo trick is illustrated as follow.
PostPosted: 17 Oct 2011, 01:55
So, our first experiment is to generate a simple counter / repeat.
Here is the ICE tree and its result.
What does it do, it count from 0 to n-1 (0,1,2 in this case as the modulo by value n is equal to 3) basically repeating these numbers four time. We can use the output from the modulo to select numbers from an arrays to feed the index input of a select from array node and repeat these numbers n times (see Stephen Blair screen at the start of the thread for an example).
PostPosted: 17 Oct 2011, 01:59
Using this trick can be advantegeous. Chris_TC used a variation of the trick to generate points on a grid like structure.
Basically, he used the Modulo to give him a basic repeat and both integers inputs to calculate the location of the next point on the grid.
PostPosted: 17 Oct 2011, 02:04
Here is my take of Chris_TC trick. Both (Chris_TC and Mine) will generate the same numbers/points.
My take is to use a combination of Modulo and Sort to generate the first series of numbers in the array (x). The second numbers are the same between Chris and I.
PostPosted: 17 Oct 2011, 02:20
Expanding in the third dimension is very similar. This time we have to generate the numbers in a certain order to get the effect we want.
Below is the ICE Tree that expand the trick in the third dimension. This can be used to select numbers in three different arrays to generate effects or points.
You will notice that the top and bottom row of nodes are the same as the uv ICE tree above. The trick is the middle row of nodes that include two modulo nodes and one sort node.
PostPosted: 17 Oct 2011, 02:25
Using the Modulo trick, here is the ICE tree of the counter I used to generate the UV numbers (between 0 and 1) for the Bezier surface.
PostPosted: 17 Oct 2011, 02:28
And the UVW version of the ICE tree (with output between 0 and 1 in x, y and z).
PostPosted: 17 Oct 2011, 02:30
Here it is, my little contribution to the modulo trick. Hope this information will be useful.
If you have a Modulo trick of your own, feel free to share using this thread.
Dan
PostPosted: 17 Oct 2011, 12:06
Interesting, thanks... ;)
This being a tutorial (of sorts) I took the liberty to move it to the "ICE Tutorials" forum
