CM_ICEPortExplorer is a set of customisable context menus to speed up ICE workflow. It allows quick placement of your favourite ICE attributes onto Set Data or Get Data ports.
Features include: Favourite ICE attributes – customisable list of your most often used attributes. Browse for any ICE and kinematics attributes available on a port. Can be split into alphabetic groups. Set port data type. Quickly clear the port or set it to ‘This.’ Records a history of the most recently chosen attributes from the context menus. In Softimage 2012 even typed-in attributes can be recorded into the history menu. All menus can be disabled or switched between top level or sub-menus. Auto management of name conversion – choosing “pointvelocity” from the menu on an empty node will automatically resolve to “This.pointvelocity”. If the set data already has a connection or entry in the name field, the menus will try to resolve that as a scene object and display its ICE attributes.
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot post attachments in this forum
