Attached are a few compound that I updated and some.
They are:
Bezier3: A coumpound in the same line as the bezier4 factory compound
DB_Bezier3: A compound with tangent, normal and up vectors outputs
DB_Bezier4: the factory compound with tangent, normal and up vectors outputs
DB_RationalBezier3: a quadratic bezier compound with weighting on each control points
DB_RationalBezier4: a cubic bezier compound also with weighting on each control points
Enjoy. Let me know if you have a use for it.
Rational and enhanced Bezier Curves Compound
A set of compounds handling Bezier curves. Contains: Bezier3: A coumpound in the same line as the bezier4 factory compound DB_Bezier3: A compound with tangent, normal and up vectors outputs DB_Bezier4: the factory compound with tangent, normal and up vectors outputs DB_RationalBezier3: a quadratic bezier compound with weighting on each control points
local backup: DB_Bezier_Compounds.zip
author site: www.romanticdesigns.ca / si-community thread
- Daniel Brassard
- DB_Bezier3.xsicompound
- (32.08 KiB) Downloaded 222 times
- Bezier3.xsicompound
- (9.02 KiB) Downloaded 207 times
- RationalBeziers.jpg (85.7 KiB) Viewed 2875 times
- Daniel Brassard
Re: Bezier Curves Compound
More compounds
- DB_RationalBezier4.xsicompound
- (38.52 KiB) Downloaded 205 times
- DB_RationalBezier3.xsicompound
- (30.31 KiB) Downloaded 186 times
- DB_Bezier4.xsicompound
- (51.67 KiB) Downloaded 204 times
- Daniel Brassard
Pictures of the compounds
- Bezier-compounds.jpg (23.44 KiB) Viewed 2872 times
Interesting.
You may want to add one more download for convenience sake,
containing all the compounds for one easy download.
Something like this (I hope you don't mind...):
- DB_Bezier_Compounds.zip
- (11.81 KiB) Downloaded 262 times
- Daniel Brassard
Re: Rational and enhanced Bezier Curves Compound
Thank Hirazi Blue for the compressed file, I don't mind at all.
