EPS from Inkscape to Softimage?
I have been trying to get a vector drawing of some curves from the Open Source vector software Inkscape into Softimage, but I couldn't get it to work. Now I'm guessing (hoping/wishing), as an Inkscape noob, it has to do with the export settings in Inkscape. So here's my question: does anyone of you know of the "magic settings" that could help me get an EPS file from Inkscape to Softimage or if not, does anyone know of a vector drawing software of the "open source" or "freeware" variety that does create files Softimage can accept more easily?
Thanks in advance, obviously... ;)
PS - I placed this under "General" for lack of an obvious other forum to place it...
Re: EPS from Inkscape to Softimage?
Unfortunately Softimage supports only older versions of the EPS format.
http://download.autodesk.com/global/doc ... d28e132830
And for you, the local link:
[url]file:///C:/Program%20Files%20%28x86%29/Autodesk/Help/softimage2012/en_us/userguide/index.html?url=files/curves_ImportingEPSFiles.htm,topicNumber=d28e132656[/url]
Can you export as version 8 from Inkscape? Or maybe open in Illustrator and save as an older version? Also, make sure there are only curves and no TIFF preview.
Thanks,
I found that page already & was afraid of that, as Inkscape doesn't seem to give me the option to save to the mentioned older format, as far as I can tell. The Inkscape export settings don't mention the TIFF preview header either.
Sadly, I don't have a way to open it in any other program yet, as I am in an experimental phase and haven't been able to decide yet if what I was trying to do, warrants the purchase of software. So if anyone knows of any Open Source/Freeware solution that does save out in the correct format for now, I could decide at a later date, if its worth the effort/money to buy myself something commercial...
I seem to recollect an earlier version had an older format for .ai export .
But failing that blender imports .svg ,I suppose you could use that to export something out that will import into soft.
Thanks for the suggestion. Note to self: Must look into Blender again... ;)
sometimes in the past the .ai import fails because the paths are not 'flattened' whatever that means , generally forcing the original illustrator file to ungroup repeatedly kind of turns the drawing into mere points rather than groups of shapes. this may be your issue rather than a format conversion. also, as far as I can remember, it was definitely an .ai file that imported not an .eps as .eps is many different types and can simply be a bitmap whereas .ai is the points you are after. and finally , don't be outdone by Blender in this issue, I'm fairly certain that some kind soul (miga) has made a .SVG importer for xsi
http://www.xsibase.com/forum/index.php? ... adid=29685
thats so cool...pity its offline now.
This should really be on rray.de
That was a cool plugin, no doubt. But IIRC it was never even compiled for x64... ;)
aww sorry Hirazi - Blender it is then
I'm surprised no one has come up with an ice system for curve/strand booleans yet..its something sorely missing from soft.
- AceMastermind
I have attached the file to this post:Manticor wrote:thats so cool...pity its offline now.
Thanks ace.
Sadly after an hour or so trying different versions of inks cape with different export settings I couldnt get anything into xsi 7. The plugin loads but no cigar .
Users browsing this forum: brandwatch [Bot] and 33 guests
