3delight tests
Blob Strokes
Here's a small ICE compound used to generate these 'blob-strokes'. I had something
like this before, but I really wasn't so excited by the speed of generation. Now with
3delight, it's definitely feasible, updates are performed immediately. The compound
creates particles on curve list, evenly distributed, count is relative to particular
sub-curve length (still, you'll need to take care of curve re-parametrization). It's
also able to perform 'write on' on one-after-another subcurve (by sub-curve, or normalized
by sub-curve length). In short, you can 'draw' 3d strokes with it, by animating the
slider value. There are a few additional parameters. [..] contd. under si-community link
local backup: Emit Blobs From CurveList.xsicompound
author site: http://www.matkovic.com / si-community thread
3Delight
v4.0.41 updated Feb 21st 2015. 3Delight is a fast, high quality, RenderMan®-compliant renderer designed to produce
photo-realistic images in demanding production environments. The renderer was introduced
to the public in the year 2000 after being used for more than a year as the sole renderer
in a sister production company. It is now widely used and earning a reputation as
a benchmark in rendering technology. [..] (cont'd on product page)
DNA research recently released the 4.0.41 upgrade along with making the free license now support up to 8-core CPUs. Highlights from the changelog: Volumetric Smoke and Shards Any shader as light source projection Exposure, Gamma Controls Mesh Light support ESC to stop render. Last year's big 4.0 update introduced features such as: support for deep EXR files Native MARI textures support Improved sampling of environment maps Added the physically plausible 3Delight Material "Continuous rendering" is now enabled by default Up to x2 acceleration in hair/fur rendering Memory usage is down 30% when using the path tracer Skin shader for 3Delight for Softimage Motion Map property is now supported
A list of movie project rendered with the 3Delight renderer. As mentioned the product is free of charge for the first 8-core license. Additional quad-core licenses are available for 400$ each and unlimited multi-core licenses for 900$ each. Yearly support and updates 190$/290$ resp.
company page: http://www.3delight.com / product page: /en/index.php?page=3DFS_features / resource base / si-community thread (updates) / si-community thread (render tests) /
Re: 3delight tests
I've already posted some point-based hair renders in this thread, but for these, I've hacked appropriate sl files to get it properly - now it's available for everyone. Generally, point-based approach seems to be much slower (even I didn't bothered that much with tweaking of this).
Only for hairs and a white lambert on character, mentioned setup renders in about five minutes with 2 core 3delight, on 1536x2048, together with shadow map generation. BTW that's a lighting setup for entire character. For hair only, I'd would go with much less than 20, having a much more room to avoid the flicker.
What I didn't want to bother people at Area, it's a huge influence of hair density, ways of interpolation, that only ICE can handle effectively. Especially for short hair-fur, not big deal to create some kind of signed distance field, or shading transfer entirely with ICE. Unfortunately, I didn't found a way for packing that 'ICE lighting' in ready-to-use public compound.
afaik, there is much more to come (even for SI users ), related to hair/fur in 3delight, but I think there is no sense to talk about in advance.
cheers
cheers
Re: 3delight tests
Hey Mathaeus.,
That looks really awesome. Can you tell me how did you set up SSS? For me it doesn't want to work, there's a quite large difference between MR's SSS and 3delight SSS. I figured out that it's some kind of issue with scaling, but not sure
Re: 3delight tests
Hi Jester,j3st3r wrote:Hey Mathaeus.,
I know you know this, 3delight just emulates the mi_sss_fast stuff, internally that's a different shader, with ability to do a color variance by itself. If you'll get the same result in every condition, that would be miracle, I think.
How does it match the scaling of subsurface effect, it seems it's defined in "misss_fast_shader.sl" in RSL folder (I know you're coder too ).
You'll find the code about scaling somewhere after "uniform float scale = i_scale;"... Before this, there's what shader is doing in subsurface precomputing phase ....., after this, there are subsurface scattering parameters.
What final result (in 3delight) you'll want for for human skin at 1SI Unit= 10cm, it seems to be something around 0.012 - 0.016. I got this value from hillybilly test by xsi base member kissb, it worked nicely for me too.
For this image, I've used something from my kitchen, what you'll already get by applying a 3dl subsurface attributes to object with any standard XSI shader, but with two modifications: shading in precomputing phase is changed to 'all direction' ( Nn instead of default Nf), and ability to multiply the scattering by color/texture. As it is for now, it looks like a good old Diffusion or Md SubScatter - just one layer, back-scattering is not so pronounced. Preset is "Skin2". Even it works nicely, I have no idea does it cause problems somewhere else.
Re: 3delight tests
Thanks Mathaeus,
I still struggle with it, for some reasons, playing with the SSS parameters seems to produce bit "unpredictable" results...Interesting that using the fast skin seems to be OK is, but again, the scale issue...But the hair rendering, is sooo nice in 3dl, so I'll try my best to figure out a proper sss to me...
Re: 3delight tests
Hey Mathaeus,
How do you render eyes? The usual setup seems to be not working, I used to have a separate object for the cornea, with transparency and reflection, and an object for the white part and iris, etc. Now when I render it, it's black...
Re: 3delight tests
Separate objects, no shadow casting for both.j3st3r wrote:Hey Mathaeus,
What you posted on 3dl forums, looks like too high ray trace bias. Default is 0.01, I think. You could set this to 0.001. Once shadows will come, you'll probably want to apply the 'hit mode' property, set this to 'use material for shadow ray', plug something into shadow port. For deep shadow maps, appropriate option in global render options.
Re: 3delight tests
Thanks for the tips, I've tried them, but no success...seems that 3.0.8 is buggy a bit
Re: 3delight tests
Congrats on that! Well deserved!Mathaeus wrote: now a shameless plug (but somehow I'm not sure how many SI-community visits the Area too ) - latest image is on Area front page for a while.
Re: 3delight tests
just as a late question:
what are deep shadow maps?
is it the same like shadow maps, which are in the rendersettings?
SI 2015 @ WIN7-64
Re: 3delight tests
Good job!
Shadow map = 2 color-only shadow map, no transparency
Deep shadow map = Pixar's original "with tranparency" shadow map format (pdf)
Detail shadow map = mental image's version of deep shadow maps
Volume shadow map = Softimage's GUI name for MR detail shadow map
Re: 3delight tests
hey thanks! (and good job too for the area post!)
i don't find a way to activate deep shadow maps in 3delight...
it should be possible, but i don't find something in the docs nor the ppg of 3delights render settings...
using the maps in the shadow maps tab renders for ages...
SI 2015 @ WIN7-64
Re: 3delight tests
Hi,caledonian_tartan wrote: i don't find a way to activate deep shadow maps in 3delight...
you enable the deep shadow maps in the same way as with Mental Ray, in Shadow Map tab of light's PPG. For colored deep shadow map, procedure is:
1: in global render options, under Shadow Maps, enable 'Surface' for shadow map shaders
2: apply a 3delight's 'Hit Mode' property to object or group, set 'Run Material' for Shadow Rays
3: put something into the shadow slot in rendertree, let's say Color_Save_State, or Constant material.
cheers
- TwinSnakes007
Need help getting started
I'm really having a hard time getting my head around 3Delight rendering. Are there any tutorials or can someone provide a scene I can study?
Thanks.
Thanks.
Re: 3delight tests
There is an older tutorial series made by "Chinny" (Jason Brynford-Jones) from Softimage, but he uses XSI 6.5 and an older version of 3Delight for Softimage as well. Still worth watching as a basic introduction IMHO
Re: 3delight tests
Speaking of CSG... anyone know if there is a trick to getting it to work right, beyond the description in the user manual? When I set up a simple test, with two intersecting spheres, (sphere B has the 3Delight CSG property, set to subtract, and is a child of sphere A), the "cut" surface will only respond to ambient light (no shading), and is controlled by sphere B's material.Mathaeus wrote:CSG
This is a render-time CSG ( constructive solid geometry, Boolean operations ).
I'm using SI 2012 SP1 (64-bit) and 3Delight 3.0.11
-Jim
Re: 3delight tests
-Jim
as far as I can recall (didn't played with CSG since this scene), setting XSI geo approx to more than zero, or using a Renderman subdivs ( 'smooth subdivision threshold' on zero), made it to work as expected.
Anyway, here is the thread in 3delight forum, about CSG and related stuff. There is also a link to XSI model I've created for these CSG renders.
cheers
