It is currently 24 May 2013, 06:25
Post new topic Reply to topic  [ 34 posts ]  Go to page Previous  1, 2, 3, 4  Next
 Post subject: Re: ICE Modeling Workshop 2: Cut edges
PostPosted: 16 May 2011, 14:11
Great work Chris! I'm still trying to get my tree to work. Hopefully i'll get a couple more hours tonight to 'burn' on this :)
As for slicing both sides of the mesh, I was thinking about that. I thought one possible way is to take each polygon normal and only slice a polygon if its normal is at an angle of less than 90 deg with the up vector (so that the plane does not slice polys on the other side). But I am not there yet :)
@Hirazi: sure i'll add a post in the compound section tonight
Claude
PostPosted: 16 May 2011, 16:02
Excellent, I look forward to seeing your tree. Many ways to skin a cat in ICE..
That's a great idea, and it works in the case of a tube. But if you make the geometry "wavy" (e.g. push one side of the tube towards the tube's interior) it doesn't give the correct result.
I wonder whether Guillaume even thought of this. In his video he uses flat one-sided geometry, so the issue doesn't come up.
PostPosted: 24 May 2011, 04:30
It's been a while, but i've finally got a decent result. I've upload a video on vimeo to go through the ICE Tree:
You can download the scene from http://claudeonthe.net/scenes/cutting_edge.zip
I think the main differences would be around the use of a new basis and a matrix transform rather than dot and cross products to decide if an edge is to be split.
Claude
PostPosted: 24 May 2011, 22:17
Very nice! Judging by the video, your method for figuring out which vertices to connect is much better than mine. Your compound should perform way faster.
Guillaume has been pretty quiet so far. There is still time for others to chime in.... don't be afraid, start plugging nodes, people :D
PostPosted: 24 May 2011, 22:44
I just noticed that the compound I previously uploaded doesn't work because for some strange reason one node was not exported. Here's a functioning compound.
EdgeCuttingWIP5.xsicompound [74.28 KiB]
Downloaded 61 times
PostPosted: 25 May 2011, 04:51
Nice one Claude and Chris !
Sorry for being so quiet those days. I'm rather busy on some other stuff.
But I'm really happy to see that other ICE users are continuing the workshop without me :).
I just watched Claude's video and the principles looks really close to my ICETree (if I remember correctly). But I don't think that I used any repeat nodes in my setup btw...
I will try to find the time to clean my version and will of course share it on the web too. So we will have at least three solutions to split between vertices in Softimage ;) .
Happy ICE Modeling,
Guillaume
PostPosted: 26 May 2011, 04:24
LOL that sounds like a challenge, I had to revisit !!!
So I've found a way to get rid of the iteration, actually ends up simpler than the usual iteration.
Claude
PostPosted: 31 May 2011, 13:10
Here is finally my version of the Cut edges :
http://dl.dropbox.com/u/5533643/Softimage/workshop/ICEModelingTools.0.2.xsiaddon
Once the addon installed, you must refresh the ICE preset manager (or just re-start Softimage).
If you installed the version 0.1 sent on the Softimage mailing list some weeks ago, first uninstal it.
And here is how to use it with the context menu : http://dl.dropbox.com/u/5533643/Softimage/workshop/ICEModelinToolsDemo02.swf
The addon also include the "Cap Borders" compound of the first workshop and a couple of other compounds (already published on some forums or list) to centralize the stuff a little bit.
So here is what you will find in the addon :
- Apply Slice Between Two Vertices
- Apply Thickness
- Cap Borders
- Create Bullet Shattered Primitive
- Create Copies from Polygon Mesh.2.0
- Create Extrusion Along Strands.2.0
- Deform Strand Extrusion
Guillaume
PostPosted: 31 May 2011, 22:59
Thanks, already using 3 of those on my models :)
PostPosted: 10 Jun 2011, 17:19
Thanks Guillaume!
http://sorairoblog.blogspot.com/
