I did some googling without much help and smoothing the fcurve in the animation editor didn't do much. I have a character that is swinging a lightsaber in a diagonal motion and I get some odd "wiggle" in the wrist rather than a smooth diagonal swipe. There are only 3 keys across 20 frames. Is there some way to smooth this out?
LMK if a video or something would better help explain, didn't take one just yet since I don't have camtasia installed atm.
Smoothing out motion
Re: Smoothing out motion
OBS Multiplatform screen recorder is probably the best free one out there. Has great framerates.
Concerning.. rotation, sometimes switching out your bezier keys for linear keys to see at what point the axis is wobbling, maybe you can fix it with more linear keys, then bake them, smooth them out, then simplify.
The axis is probably flipping from 360 to 0 again but through a curve instead of a stepped key switch.
Rotation is a bit of a pain... sometimes animating in quaternian is better than euler for those wobbles.
I'm not sure what is the problem, but if you want to make the wrist movement smooth no matter what movement the arm is doing, then you could constrain the wrist rotation to a separated controller that isn't under the arm controllers, so it won't be affected by the movement of the arm.
And, I wouldn't do it but you could use global animation for the wrist too.
Why would you avoid global animation for the wrist, Myara? I'm a beginner and I'm just curious.myara wrote: ↑18 Aug 2017, 09:24 I'm thrilled with these pellet smokers and not sure what is the problem, but if you want to make the wrist movement smooth no matter what movement the arm is doing, then you could constrain the wrist rotation to a separated controller that isn't under the arm controllers, so it won't be affected by the movement of the arm.
It’s just a matter of preferences. I prefer to have my controllers on sight and know right away what they are doing. Global keys will make me dig a little more and for me it gets messy and confusing changing the space and using the animation editor more than needed. You may have some problems plotting and combining both spaces too.
I usually animate characters and after doing the main motion I’d have to move the root controller to add some translation animation and if the key is global it will get stuck in the global space.
If I use a constraint and a controller I can see in the viewport what is going on directly and let’s me tweak it easily.
