Is there a way to use the knife tool to make an object into to 2 objects?
Thanks,
RYan
knife tool
Re: knife tool
What you want is the split edge tool, then you can break up one object into multiple objects, which is the direction you want for dynamics
Re: knife tool
Say I have a complex piece of geometry.
And I slice this geometry on an angle, I want to delete one half of it...And since It is an angled Cut I can't select the half in an orthographic view , But I have to go in and painstakingly select polygon by polygon along the knife cut.
If The cut would make the object Into two objects , Then I could just delete one half.
Hope this makes sense..
I will try to post a pic
Re: knife tool
All of the selection modes seem quite sloppy and slow for something like this...
If softimage had a polygonal lasso mode it might be better... But there has to be a way to cut an object into 2 with the knife tool ?
- Daniel Brassard
Re: knife tool
Re: knife tool
Perfect!
Thank you daniel!!!
Don't know how I missed that, The slice property dosen't automatically come up for the knife tool.
Went into the exlporer and found it.
Problem solved
Thanks Again
Thank you daniel!!!
Problem solved
Thanks Again
Re: knife tool
Or simply a difference boolean op ? create a cut box and substract it
