Page 1 of 1
Selecting in C4D
Posted: 01 Oct 2014, 23:15
by Bullit
I am struggling with C4D selection, i mean when i want to change selecting one element to several making a . In C4D it seems to not deselect automatically what i selected if i click outside the element selected.
This is linked that i can only select one element with Move. If i use Live or Rectangle i inevitability end up select a bunch of elements.
Re: Selecting in C4D
Posted: 03 Oct 2014, 13:41
by pluMmet
You are getting very specific... I think it's time to go over to a C4D forum
Posted: 03 Oct 2014, 21:54
by Bullit
Ok.
Posted: 12 Nov 2014, 18:14
by noseman
Hi guys,
sorry for not responding earlier.
So in C4D, the Move Scale and Rotate tools have a slight selecting functionality. If you just click on a component, you can select it, and if you shift select you add, and CTRL select you subtract, BUT they don't have "paint" selection (click and drag). If you simply click in an empty space it will deselect, but if you click and drag it will move the selected.
In that case you should use the Live selection tool (Arrow).
Now the good news: If you have the move tool selected and then you select the Live selection tool, by pressing the spacebar you go back and forth from Selection to Move. So you move, press spacebar, select, press space bar to move again.
I hope that helps
