Maya 2018
Re: Maya 2018
They're still actively working on Bifrost's ICE-ish environment for Maya. MASH is a different thing; it's a set of DG nodes and easy user interface for motion graphics artists. Bifrost Fluid is based on Bifrost, but its node graph isn't exposed to the users right now. There aren't enough general nodes in there yet, just what the Fluid developers made for their own needs. I'm somewhat involved with those developers through the Node Editor API part.
Re: Maya 2018
good realase, can't say more, not impressive but still not bad
cant understand what Maya dev's what achieve adding all those features may be ofc they usefull but why lol
shift extrude, UV, Floating Shelf finnaly
and 10(or something) year later they adding Circle script
Good job -)
Edit: with Shift Extrude and Duplicate work way faster for some kind of basemeshes for Sculpting
Circularize doing exellent work
but after all Maya has same problem as before
Good job -)
Re: Maya 2018
@Luceric
I am about to dive into Maya 2018 here shortly, and looking at the features - the Shift Extrude is a big one to me, as similar to a thread on here where we talked about something similar. I filled out the survey to make "Maya more streamlined" right before Maya 2018 came out, and a few of my suggestions in that survey were already implemented in 2018, so that was nice to see. Since you are here, I thought maybe I could share a couple of ideas that would help bring some things more inline with the new Shift Extrude function, and get your thoughts.
(Shift Extrude - being the base assumption)
Incremental (Ctrl + Shift): This would work depending on what Translation/Scale/Rotation the user is using. Pressing Ctrl+Shift while Rotating an object with rotate it in degree increments...right now it is the "J" key, but that key is halfway across the keyboard. Pressing Ctrl+Shift while Scaling, would step the scale increments while also Zeroing out at "0" flattening out your selection (i.e. a selection of Vertices). Pressing Ctrl+Shift while moving an object steps it a certain distance.
Snapping Toggle (Ctrl): I think it would be great to set your Snaps (check the boxes you want to use at the top of the screen - i.e. Vertex, Grid, etc.) and then pressing Ctrl to enable that Snap. This allows for multiple setups and enabling that by pressing only one key. Also, I believe this is the process now but I am going by memory...in Softimage, I can move my selected objects and then press Ctrl if I want to enable snapping. In Maya, I have to first press the key I want to snap (i.e. X for grid) and then I can move my geometry. If I don't press the snapping key first, I have to release my objects, press the snapping key first and then snap to what I want. Softimage method is really efficient to me with its setup.
Those are the main ones above I was thinking about, the others would be a toggle for COG (Center of Geometry option) for gizmo positioning; a toggle for 'tweaking' - unless this was already added/changed; Raycast/Marque selection separation where camera based selection can be on one setting but not the other regardless of what shading mode is enabled; and having the TRS gizmo be separate, like it is in Softimage, for quick modeling needs being able to move/snap that on the fly on a temporary basis.
As writing this I am going by limited memory of Maya right now, but I just wanted to share some ideas. Not everything to me is about speed, as I like quality more, but I thought these areas could help improve efficiency if you guys are open to ideas.
Re: Maya 2018
Sorry, I totally got out of passing along UI and workflow suggestions.Rez007 wrote:@Luceric Since you are here, I thought maybe I could share a couple of ideas that would help bring some things more inline with the new Shift Extrude function, and get your thoughts.
The Maya team monitors the forum here https://forums.autodesk.com/t5/maya-for ... /area-b201, anything you post there should be seen by the right people.
Re: Maya 2018
I will try there. Thanks for the info.luceric wrote:Sorry, I totally got out of passing along UI and workflow suggestions.Rez007 wrote:@Luceric Since you are here, I thought maybe I could share a couple of ideas that would help bring some things more inline with the new Shift Extrude function, and get your thoughts.
Users browsing this forum: No registered users and 78 guests
