Page 1 of 2
Challenge: Make the fastest island selection compound
Posted: 12 Feb 2012, 16:11
by Chris_TC
Hey folks,
The challenge is to make the fastest polygon island selection compound possible. Your compound has to work out of the box, as we don't want to install plugins, addons, workgroups or anything else (so I think you will need to rely on factory nodes).
I have attached my own polygon island compound along with a test object for you to compare performance. Please make something much faster, or pimp my existing compound
Depending on the island, my compound outputs the same polygon indices multiple times. I don't mind because it's not typically a problem for ICE Topo. If you prefer to output only unique indices, feel free to go for it. But it'll likely slow down your compound.
P.S.: Just in case you were wondering, the idea for this was proposed to me by someone on Vimeo after I asked for a fast polygon island compound in my latest video.
Re: Challenge: Make the fastest island selection compound
Posted: 12 Feb 2012, 17:08
by iamVFX
Is it necessary to input a polygon index to select the island? If not, you can just wrap
Bradley's script into a compound via PPGLogic, so on compound creation it's creates a clusters and on change of index value it's filter them
Posted: 12 Feb 2012, 18:39
by Chris_TC
iamVFX wrote:Is it necessary to input a polygon index to select the island?
Yes.
Posted: 12 Feb 2012, 19:25
by Chris_TC
After trying out some more things, I've managed to speed up the compound considerably. On the test geometry it's about
5 to 6 times faster than the one I posted previously. I will not post my updated compound yet - it is supposed to be a challenge after all
Just a hint: I got rid of one of the loops.
Posted: 13 Feb 2012, 01:08
by Mr.Core
Here is CG Find Polygon Island result ( 2 m 3 s ):
http://xmages.net/storage/10/1/0/1/3/up ... 5e5f85.jpg
And here is my ( 1 s ):
http://xmages.net/storage/10/1/0/6/2/up ... d9f224.jpg
It takes one int as polygon index and outputs rest of faces from the shared island ( no duplicates )
I have complicated your geo example a little bit because it has been calculated both on my and your compounds mostly at real-time, and have attached my own compound, check it out please, I am not sure that it works as expected but seems like it does that
Posted: 13 Feb 2012, 15:20
by Chris_TC
I have checked your compound, but it doesn't give me proper island selections. It seems to always select several islands.
I have attached a new test object and my updated compound. If you could fix yours, that would be awesome. It seems very fast!
Posted: 13 Feb 2012, 15:58
by Mr.Core
Hi Chris,
On which scene you have checked it ? On the "testscene2" ?
I have tested it there and really encounter some strange behavior, but it has been solved by adding "build from set compound"
http://clip2net.com/s/1AzEo
Could you please share a scene with this problem ?
Posted: 13 Feb 2012, 17:49
by Chris_TC
Mr.Core wrote:Hi Chris,
I tried with many different objects (also made new scenes just to be sure), but it didn't seem to work with any.
For example, when I use your compound with the first test object I posted and set your compound to index 1, it extrudes two polygon islands. If I use a Build Array from Set, it extrudes all polygon islands.
Posted: 13 Feb 2012, 17:58
by Chris_TC
I made a new scene. Made a standard 8x8 grid. Deleted the 2 middle rows and columns. Then used your compound set to index 25:
Posted: 13 Feb 2012, 18:27
by Mr.Core
Its a quite strange result
I have got next : http://clip2net.com/s/1AC56
I have also attached my scene,2012 sp1\ x64
Posted: 13 Feb 2012, 19:27
by Chris_TC
Mr.Core wrote:I have also attached my scene,2012 sp1\ x64
I opened your scene, and all 4 islands are extruded. If I remove the Array From Set, I'm back to the 3 islands from my screenshot.
Someone else is going to have to take a look, maybe something is broken on my end.
Posted: 13 Feb 2012, 19:51
by milanvasek
i tried Mr.Core's scene and got the same result:
2012 SAP, 64bit
Posted: 22 Feb 2012, 18:14
by Chris_TC
I also tested the compound at work, but I get the same erratic behavior. I'm not sure why
Regardless, everybody is free to add their compounds to the mix...
Posted: 01 Apr 2012, 23:42
by gustavoeb
Im currently building something related, but not quite the same... Im currently using a setup that is a slight variation of the method on Gui's Lafforge blog:
http://frenchdog.wordpress.com/2010/03/ ... ng-arrays/
Im using a slightly different while loop, and a different way to organize the indexes... Anyhow it should be able to select from a PolyInput, and I dont find it that slow... Is anybody doing somehting completaly different?
I found a lot of broken links in this thread, so my question is:
What is the fastest working compound until now? So I can compare mine...
Posted: 03 Apr 2012, 19:53
by grahamef
gustavoeb wrote:Im currently building something related, but not quite the same... Im currently using a setup that is a slight variation of the method on Gui's Lafforge blog:
I'm interested in knowing that too. I was thinking of trying that technique myself but I haven't had the time lately.
Posted: 18 Apr 2012, 15:05
by gustavoeb
my similar technique doesnt work on islands with very messed up geo
I had to make it slower, but even then it wont support islands with veeeeeeeeery messed up geo
Ill just have to copy and paste Guis work and start from there again, but Im being lazy lately
