ICE - Modulo trick and variants
- Daniel Brassard
- Contact:
Re: ICE - Modulo trick and variants
Thanks Hirazi Blue.
Thank you for the thread. Even though I use the modulo trick, I always have to do trial and error because it requires a somewhat unusual way of thinking.
Is there a specific thread on XSI list that discusses it?
- Daniel Brassard
- Contact:
Thank Chris.
A couple of threads on XSI List are about using the modulo trick to avoid the repeat node and multiple mention of the trick to generate sequential numbers, but I have not stumble yet on a specific thread about the trick itself. That is why I create this thread.
The closest, is probably the one from Steve Blair on XSI Support.
http://xsisupport.wordpress.com/2011/05 ... -compound/
- Daniel Brassard
- Contact:
This trick use the modulo to create the quad description for my bezier patch topology.
You can use this trick to create the polygon description of a grid topology of any U and V size!
Simple, effective and quick! No repeat here!
- Attachments
- Modulo_quads.jpg (60.01 KiB) Viewed 3086 times
Users browsing this forum: No registered users and 15 guests
