It is currently 20 Jun 2013, 10:36
Post new topic Reply to topic  [ 55 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6  Next
Author Message
 Post subject: Re: ET_AnimStore
PostPosted: 06 Jun 2010, 12:33
Offline
Looking at your logged messages, this doesn't look like a Python problem...
Is the viewport the plugin captures from visible?
There's a mention in the video that it must be...
BTW - Editing the " __init__.py" within the Softimage Python install should do the trick, just make sure that "Use Python Installed with Softimage" is checked in the "General Preferences > Scripting Preferences".
_________________
"Forsan et haec olim meminisse iuvabit." (Virgil)
Top
 Profile
PostPosted: 06 Jun 2010, 18:02
Offline
ivemaker wrote:
HI eric, in your tools, error with __init__.py, it because, i think, you're wrong hardware render viewport.
i use this code to render viewport and it work nice! And when i use this code I dont edit a __init__.py file
Code:
currFrame = app.ActiveProject.Properties('Play Control').Parameters('Current').Value
   oViewportCapture = app.Dictionary.GetObject('ViewportCapture');
   app.Dictionary.GetObject("ViewportCapture.Start").Value = currFrame
   app.Dictionary.GetObject("ViewportCapture.End").Value = currFrame
   app.Dictionary.GetObject("ViewportCapture.Filename").Value = '1.jpg'
and etc. This code is based on my study of Python.
Arthur
I'm sure this works too. However editing the __init__.py is universal and fixes more than just my scripts. Both our methods work, just one works without the __init__.py edit. I'll take your suggestion into consideration on further updates to my plug-in.
_________________
Eric Thivierge
ethivierge@gmail.com
http://www.ethivierge.com
http://www.exocortex.com/products/species/
Top
 Profile
PostPosted: 06 Jun 2010, 20:02
Offline
The whole Python Dispatch fix issue still confuses me:
The problem originates
Quote:
due to XSI returning an object with an incorrectly set multi-dispatch interface (quoted from here)
However, the Softimage WIKI states the following:
Quote:
In versions prior to v6.0 XSI sometimes returned objects with an incorrectly set (as per PythonWin standards) multi-dispatch interface. This problem has been fixed in v6.0. (quoted from here)
So maybe someone could answer this question once and for all:
is the good-old mult-dispatch fix still necessary, or not? :-\
_________________
Top
 Profile
PostPosted: 06 Jun 2010, 20:23
Offline
I believe so. Otherwise people using my plug-in wouldn't have to edit the __init__.py file. :)
_________________
Eric Thivierge
Top
 Profile
PostPosted: 06 Jun 2010, 21:25
Offline
Hello everyone
Second attempt I uninstall python (C: \ Python)
I use python I provided with XI edit file __init__.py
I have another error message
When I store pose:
Quote:
# WARNING : ET_AnimStore_PoseCam was not found and will be imported. Please press store pose again.
# INFO : 4152 - Data loaded from file C:\Users\Megacortex\Autodesk\Softimage_2011\Addons\ET_AnimStore\Application\Plugins\..\..\Data\Models\ET_PoseCam.emdl was created with build number: 7.0.2008.1125 - compatibility version: 700
when i inspect pose:
Quote:
# ERROR : Erreur de syntaxe - [line 12]
# WARNING : 3000 - Error parsing D:\_3D\XSI\Projet Blog\AnimStore\Character\Biped\Pose\Default\PoseName\PoseName.htm
# ERROR : Fin d'instruction attendue - [line 4]
# ERROR : Property Page Script Logic Error (Erreur de compilation Microsoft VBScript)
# ERROR : [2] (null)
# ERROR : [3] import os
# ERROR : >[4] from win32com.client import constants as c
# ERROR : [5] from win32com.client import Dispatch as d
# ERROR : [6]
With this change I do not have the same mistakes
I have a folder that is created AnimStore in my project
if I open this folder I see PoseName.htm it's a blank screenshots ??
Thank you in advance
_________________
'ERROR : 2011 - Unable to write well in English [CLSID\{F123FC55-ABD9-4D7F-9CDD-7F9D61E71FFE}] : %SUMATRAPATH%\ English.dll not found'
Top
 Profile
PostPosted: 06 Jun 2010, 21:31
Offline
Looks like your scripting language is set to VBScript... :-\
Did you check the "Use Python Installed with Softimage" checkbox in the "General Preferences > Scripting Preferences" after uninstalling your " other" Python?
PS - @ Eric: you're right, your plugin doesn't work without the fix...
That still leaves the question unanswered, what is meant with the statement I quoted from the Softimage Wiki...
_________________
Top
 Profile
PostPosted: 06 Jun 2010, 21:36
Offline
zossowosso wrote:
Hello everyone
When I store pose:
# ERROR : [6]
I don't suggest using the factory installed Python that comes with Softimage. If you do and you edit the file within that factory install, you probably need a restart of your system and after restart ensure that Python is listed as a scripting language. You probably need to have Pywin32 is still installed too.
Honestly it's in my opinion that you should install Python separately and follow these directions:
http://www.vimeo.com/12097088
Your error is saying that the .htm file is failing to run a VB Script. Funny because the .htm file is supposed to be running a Python script within it. Please follow the video. Also ensure that you are installing the correct version for Windows 7 64-bit:
http://usa.autodesk.com/adsk/servlet/item?siteID=123112&id=14003492
_________________
Eric Thivierge
Top
 Profile
PostPosted: 06 Jun 2010, 21:40
Offline
As it looks you're not using Softimage 2011 I wouldn't necessarily draw too many conclusions about it. If there's a Python within your Softimage 2011 you can use it and you can edit the necessary file within this "embedded" Python without a problem... I can attest to that... ;)
edit: And I can say: the plugin works (after the fix) so it's nothing to do with the embedded version of Softimage 2011
_________________
Top
 Profile
PostPosted: 06 Jun 2010, 22:38
Offline
Hello Eric
ok I tried with a fresh installation of python
it's stange beacause if i don't edit the __init__.py file i see your plug
but if I edit I no longer see it
:-\ :-\ :ymblushing:
I think I have a problem here I'm sure the plug is correct
I'll try to find the problem thank you again for this attention
Quote:
the way I install
Instructions for installing python on Windows Vista and XP 64bit.
NOTE: All required files are supplied with PythonInstall64.zip
1) Put User Account Control (UAC) to off (Vista only)
http://technet2.microsoft.com/WindowsVista/en/library/0d75f774-8514-4c9e-ac08-4c21f5c6c2d91033.mspx?mfr=true
2) Install VC 2005 and VC 2008 Redist
vcredist_x86.exe
vcredist_x64.exe
3) Install Python 2.6
python-2.6b2.64
NOTE: Python 2.6 version is now required for vista and XP 64, older versions of python cannot be supported.
4) Add the python folder installation (e.g. C:\python26) to the PATH environment variable as the installer won't do it by default.
5) Install pywin32: pywin32-212.win-64-py2.6.exe
New Error
Quote:
# INFO : ET_AnimStore_PoseCam was found.
# File "<Script Block >", line 341, in ET_AnimStore_StorePose_OnClicked
# oPoseTextMesh.Properties["visibility"].viewvis = 1
# File "C:\Python26\lib\site-packages\win32com\gen_py\269C4D8C-E32D-11D3-811D-00A0C9AC19A9x0x1x0\PropertyCollection.py", line 96, in __getitem__
# return self._enum_.__getitem__(index)
# File "C:\Python26\Lib\site-packages\win32com\client\util.py", line 37, in __getitem__
# return self.__GetIndex(index)
# File "C:\Python26\Lib\site-packages\win32com\client\util.py", line 42, in __GetIndex
# if type(index)!=type(0): raise TypeError, "Only integer indexes are supported for enumerators"
# TypeError: Only integer indexes are supported for enumerators
# - [line 340 in C:\Users\Megacortex\Autodesk\Softimage_2011\Addons\ET_AnimStore\Application\Plugins\ET_AnimStore.py]
# ERROR : Property Page Script Logic Error (Python ActiveX Scripting Engine)
# ERROR : [338] else:
# ERROR : [339]
# ERROR : >[340] # Unhide pose text mesh to capture with icon
# ERROR : [341] oPoseTextMesh.Properties["visibility"].viewvis = 1
# ERROR : [342]
# ERROR : [343] oModel = PPG.Inspected(0).Model
_________________
Top
 Profile
PostPosted: 06 Jun 2010, 22:52
Offline
In your video you don't mention editing the __init__.py file. Did you do this? This is essential!!!! This is where the error is coming from.
Also after you deactivate the factory Python install, restart Softimage.
Also, you have the ET_AnimStore set to capture from viewport A. Viewport A isn't visible. You must have it visible.
_________________
Eric Thivierge
Top
 Profile
Search for:
Jump to:
