Motion Tools 1.0
Motion Tools 1.1
Project moved to GitHub in Jul 2017 --- Motion Tools is a small collection of tools that aims to aid Motion Graphic work being
created inside Softimage. The idea is to create a workflow for the creation, distribution
and animation of instances as intuitive as the ones found in comercial solutions.
Since it is created ontop of ICE the tools have speed and combustibility considerably
superior to similar solutions.
Demo video available here. For demos of the previous beta versions, see here vor v0.1, here for v0.2 and here for v0.3.
local backup:motiontools.zip
author site: http://gustavoeb.com.br / download: /mtools / author @ vimeo / project @ github / si-community thread
Motion Tools 1.1
Updated September 2012 to support polygon island pivots/rotation fixes. Motion Tools is a small collection of tools that aims to aid Motion Graphic work being
local backup: motiontools.zip
Re: Motion Tools 1.0
Hey guys, v1.1 is out. Nothing big some of the rotation problems discussed in this thread are gone (I hope) and a pivot for constrained polygon islands was added. There is a new sample scene in the sample scene folder showing how to use this feature.
No news on the MB front, sorry MR users but my time to work on this is limmited
As usual as files and release notes can be found here:
http://www.gustavoeb.com.br/mtools/
Gustavo Eggert Boehs
- Contact:
awesome
thanks for all your hard work, this has totally become one of my Favorite tool.
- Contact:
hey Gustavo
I Just installed the MT 1.1, but the animation clip doesnt seem to work. and nor does the pivot for constrained polygon islands. i tried using both 2012 and 2013.
might be be doing something wrong?
- Contact:
for the few guys who asked me to do, an "How i did it" video. on my sphere animation.
sorry about the video quality is the beginning, but after the first min. it gets better.
and please excuse all my swearing.
i tried making the video simple quick and fun.
cheers
cheers
hey Angel, thank you very much for taking the time to record and share that... great creative use of the tools
plus it is funny to listen to not like my videos.
Ill take a look into the problems you report. Was animation clip thingy working for you prior to the update? Plus, note that it will only work on 2013, as it has a little node inside which is 2013 only.
Cheers!
Cheers!
- Contact:
yeah that seemed to be the problem.
but when i try the slice poly to islands, and try to change the pivot, it doesn't seem to work. and when i do that and add an animation clip mod. the node is red.
it works but its red, i dove into it, but i couldn't see anything off the back
Thanks for the Vid! It looked awesome.
I found the swearing added to the entertainment value!
- GiorgioAdolfoKrenkel
I am having some problems when trying to use the new addon. Are the addon OS related?! Im using linux. Here are the error messages im geting when trying to use the mtools:
CreatePrim "Sphere", "MeshSurface"
SwitchToolbar 4
' ERROR : 2000 - Argument 0 (PresetObj) is invalid
' ERROR : 2027-EDIT-ApplyOp - Traceback (most recent call last):
' File "<Script Block 2>", line 256, in mTools_CreatePolyIslandControl_Execute
' oGeo_ICEtree = str(xsi.ApplyOp("ICEtree", oInputGeo, "siNode", "", "", 0))
' File "<COMObject Application>", line 2, in ApplyOp
' COM Error: Invalid preset argument, cannot load ICEtree - [line 255 in /root/Autodesk/Softimage_2013_SP1/Addons/MotionTools/Application/Plugins/mTools_ICEFlow_Plugin.py]
' ERROR : OLE error 0x80020101
mTools_CreatePolyIslandControl 1
' ERROR : Traceback (most recent call last):
' File "<Script Block 2>", line 153, in ICEFlow_CreateInstanceArray_Callback
' elif oTmp == "Slice Polygons into Polygon Islands": xsi.mTools_CreatePolyIslandControl(1)
' File "<COMObject Application>", line 2, in mTools_CreatePolyIslandControl
' COM Error: Exception occurred.
' (0x-7ffdfff7) - [line 152 in /root/Autodesk/Softimage_2013_SP1/Addons/MotionTools/Application/Plugins/mTools_ICEFlow_Plugin.py]
Also when trying to create the ice nodes in the Ice editor, ive got nothing there.Guess it will not work in Linux?!
SwitchToolbar 4
Hi Giorgio. Yeap I guess Linux is the one to blame. I have received other complaints and tried to get info from other people on the SI Mailing List. I cant promisse anything other then I will try to address this :/
But are you saying that the compounds are missing? Have you relaunched SI after installing the plugin?
It should not be the case, even in Linux, as far as I know... Nothing shows up under Tasks - Motion Tools?
Hello Gustavo.Thank you for looking this problem.gustavoeb wrote: But are you saying that the compounds are missing? Have you relaunched SI after installing the plugin?
Well, i got a node called, "Initialize PolyIsland Data". Nothing else.
yeah it is actually in known limitations. I did not implement this because is sligthly different then the implementation for existing polygon islands... but should be there shortlyangelous4x wrote:when i try the slice poly to islands
this is because the clip is not keyed in all transforms (scale, rot, trans) but as you can see it still works... I will try to fix this bogus visual feedback next updateangelous4x wrote:when i do that and add an animation clip mod. the node is red
well "Initialize PolyIsland Data" is under tools not tasks. so only tools showing up in Linux? I have no experience with SI on Linux, so Im attatching two images just to make sure we are talking about the same things...GiorgioAdolfoKrenkel wrote:Well, i got a node called, "Initialize PolyIsland Data". Nothing else.
Hey Angelous thanks again for the grrreat tutorial... did you see it got its own post from Bellsey?!
http://area.autodesk.com/blogs/graham/c ... -softimage
Ps: by the way, thanks for spreading the word Bellsey
oops, forgot to attach the images, here they go Giorgio
- Attachments
- tasks.JPG (18.28 KiB) Viewed 2336 times
- tool.JPG (14.55 KiB) Viewed 2336 times
- Contact:
Hey Gustavo
This is great there is alot of attention on motion tools. which is awesome and well deserved. again its one of my favorite tools.
they also posted it on softimage Facebook page.
http://www.facebook.com/AutodeskSoftimage
thats links to lesterbanks
http://lesterbanks.com/2012/09/using-mo ... nimations/
keep up the amazing work.
Thank you Gustavo.gustavoeb wrote:oops, forgot to attach the images, here they go Giorgio
All the nodes are present in both tabs. But i still get those error messages when trying to use the tool.
Users browsing this forum: No registered users and 25 guests
