It is currently 24 May 2013, 15:28
Post new topic Reply to topic  [ 23 posts ]  Go to page Previous  1, 2, 3
Author Message
 Post subject: Re: SSS2 Compound
PostPosted: 02 Jun 2012, 21:21
Offline
I'm curious about your lighting setups - seems like Mental Ray renders very dark unless I put an exposure
node on the camera, regardless of soft, ibl, or whatever. Without exposure on camera, when using
a spot (with attenuation, which I know will diminish the power), I generally have to turn up the
intensity to 200-1000 - just curious if this is normal. My models are all relatively to scale (10cm/unit).
Great renders - the updated sss seems much more powerful. One other question - is diffuse+SSS like an
additional 'scale' value?
Top
 Profile
PostPosted: 02 Jun 2012, 22:58
Offline
@ second question: Yes, it's a multiplier or tint for the SSS and diffuse components. It is named "overall multiplier" in the original SkinSSS, I though I'd rename it so it's more clear that it doesn't affect anything else.
_________________
Image rray.de, a resource site for softimage, updated apr 13th
Top
 Profile
PostPosted: 03 Jun 2012, 00:29
Offline
its ok, i had values of 6000 or higher for physical lights, but i render without exposure shader the most time. physical values are completely different to light without falloff and intensitys of one like in old school setups. physical sky shader for example and sun intensity values of 100 for ibl are normal settings.
Top
 Profile
Search for:
Jump to:
