Post subject: Re: mAligner-align points, edges and objects
Posted: 29 Jun 2012, 10:58
Update v1.6
Changes:
Align to Last selection Option added. Note: With points only works if the last point selection is in the last selected object.
Align Center to Last selection Option added.
Compact GUI Redesigned using View.
Changed JJ Vector Pick to Raycast Rectangle for easier selection. Added an option to JJ Vector to get the first and last point position instead of using Pick, so you can work faster with point loops.
Replaced Freeze Modeling Stack with normal FreezeModeling. (Freeze Modeling Stack code seems to affect Render Region) Note : If you are in Immed Mode it will automatically FreezeM your model. Otherwise it will leave points translation history.
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot post attachments in this forum
