Ok, final version of the plugin is here, link from the first post updated. For the last time (:
This is a small but very important update. Cache length and versions not count properly before (python doesn't sort lists by default...), so it's fixed now. DisplayInfo_Cached property are not needed anymore. It means that you should manually delete versions folders of caches to rewrite them. And code is cleaned up, it's very pretty now!
druitre wrote:
Man! Potentially huge, functionality that should be standard in SI I'd say. Thanks a lot, this may make my day on the project I'm working on at the moment.
Thanks! All my tools I made for myself, I don't know does it fit in the standard package functionality, but I know that it very useful tool to work with at least for me (: And I hope someone find it useful too!
origin wrote:
by the way, do any of you guys use SSD drive as cache repository?
SI caching is very slow, i'm on 4 hdd raid-0 now Im wondering if sata iii SSD would give me some boost...
Should do, but I don't know for sure. For me caching was always not the fastest process in the world, but it shouldn't actually, if you know that at the end you will get result that you looking for. It's like lagoa, many people mentions that it slow compare to realflow for example, but it can be slow if it does what other programs can't. Elastic-plastic-dirt things for example (:
By the way, Origin, I want to see a cmivfx tutorial for SI SDK from you someday!
I'd buy it for the high price!
