It is currently 19 Jun 2013, 04:38
Post new topic Reply to topic  [ 47 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
 Post subject: Re: XSI-->Nuke
PostPosted: 25 Oct 2010, 18:15
There was stupid little bug in the code that i just noticed today.The problem was in exporting selected camera.Sorry for that.Here is new version.
tim_XSItoNuke_v1.2.zip [9.55 KiB]
Downloaded 234 times
PostPosted: 11 Nov 2010, 17:52
Exported camera does not match in Nuke with XSI scene :/
btw, does this script export geometry as well? Or what should it export if I select pass? All I get right now is camera. Promising script! Getting camera from Softimage to Nuke has been lot of stress so far, this makes it lot easier if it would match 100% :)
PostPosted: 13 Nov 2010, 12:01
Thanks Splin . It's good to have a feedback!I didn't notice this problem because obviously I didn't make enough tests with different camera Focal Length.
Now everything should work fine.Please let me know if it's ok .Any feedback it's very welcome!
Here is ver 1.3
Next version will support geometry , lights and nulls .
Hope soon to find some time to do it.
Delete the old version before install.
tim_XSI2Nuke_v1.3.zip [9.62 KiB]
Downloaded 227 times
PostPosted: 15 Nov 2010, 12:07
Thanks, I will give it a try!
PostPosted: 17 Nov 2010, 16:01
It works fine now :)
PostPosted: 01 Dec 2010, 14:35
This version fixes padding issue with passes .The plugin was using the default XSI "#" now supports any padding.
tim_XSI2Nuke_v1.4.zip [9.57 KiB]
Downloaded 149 times
PostPosted: 03 Dec 2010, 12:50
Here is the version 2.0
New:
Now it supports geometry, lights and nulls.
Changes:
Now setups the correct rotation order automatically.
If animation exist on the object it takes the first and the last key and exports that range
If no animation it takes the scene frame range and exports global transforms values for that range.
(this is in case you parent the object to another animated object and you want to get the transforms in Nuke)
Here is demo video:
edited by gustavoeb: vim tag
tim_XSI2Nuke._v2.1.zip [12.03 KiB]
Downloaded 481 times
PostPosted: 05 Dec 2010, 10:36
\m/ THANK YOU MAN!
PostPosted: 05 Dec 2010, 11:38
\m/ \m/ \m/
PostPosted: 05 Dec 2010, 12:24
awesome,
is there any chance to export our pass through EXR buffer and have it as multipass in single file-image sequence .!? :ymdaydream: ^:)^
