Page 1 of 1
pyxPOP "beta testing"
Posted: 02 Sep 2010, 00:04
by rray
Hello once more
I've been working today on this "beta" python version of XPOP. I'd be particularly interested if it works on linux (I mean it uses the win32gui module but maybe mainwin supports it)
Once installed, it can be used from JScript and VBS, too.
Usage Examples:
Python Example:
def handler(n):
Application.LogMessage(str(n))
p = Application.XPOP()
submenu = p.AppendSubMenu( p.mainmenu, "HelloX" )
ok = p.AppendMenu( submenu, "HelloY", "Application.NewScene()" )
submenu2 = p.AppendSubMenu( submenu , "HelloZ" )
ok = p.AppendSeparator( submenu2 )
ok = p.AppendMenu( submenu2 ,"bottom", "handler(2)" )
exec(p.Track())
VBS Example:
set p = XPOP()
subm = p.AppendSubMenu( p.mainmenu, "HelloX" )
ok = p.AppendMenu( subm, "HelloY", "NewScene()" )
subn = p.AppendSubMenu( Cdbl(subm), "HelloZ" )
ok = p.AppendSeparator( subn )
ok = p.AppendMenu( subn,"bottom", "handler(2)" )
ExecuteGlobal p.Track
sub handler(i)
logmessage(i)
end sub
JS Example:
var p = XPOP();
sub = p.AppendSubMenu( p.mainmenu, "HelloX");
p.AppendMenu( sub, "HelloY", "NewScene();");
sub2 = p.AppendSubMenu( sub, "HelloZ");
p.AppendMenu( sub2,"bottom", "handler(2)");
eval( p.Track() );
function handler(i)
logmessage(i);
Thanks for reporting xD
PS I've been wondering if the old 1-long-string syntax will be still useful or if I should discard it.
Re: pyxPOP "beta testing"
Posted: 02 Sep 2010, 10:40
by Hirazi Blue
Something specific you would like to see tested
(other than if it works in Linux, which I sadly cannot test)
or do you need mere confirmation of the general "yes, it works" kind?
Anyhow, I'll try to look into it later today...
Posted: 02 Sep 2010, 11:34
by rray
Thanks for having a look Hirazi - I'm just probing the communiy to see if someone sees any pitfalls with the new method that I've been missing.
Or suggestions on how to extend it, I'm looking into adding a title for the menu as well as possibly icons
btw here's the sourcecode.. could be useful if someone's interested in doing windows programming in xsi. It should also be a nice starting point for doing things like custom drawn radial menus etc.
import win32com.client, win32com.server
from win32com.client import constants
import win32gui, win32con, win32api
class xpop:
_public_methods_ = ['Track', 'AppendMenu', 'AppendSeparator', 'AppendSubMenu']
_public_attrs_ = ['mainmenu']
def __init__(self):
self.mainmenu = win32gui.CreatePopupMenu()
self.itemhandlers = ['']
self.idcount = 0
self.pickedmenuid = 0
def CreateInvisibleWindow(self):
self.wc = win32gui.WNDCLASS()
self.wc.lpszClassName = 'win32gui_invisiblewindow_class'
self.wc.lpfnWndProc= { win32con.WM_COMMAND:self.OnCommand }
self.class_atom=win32gui.RegisterClass(self.wc)
self.hwnd = win32gui.CreateWindow(self.wc.lpszClassName, "Invisible message receiving window", win32con.WS_CAPTION|win32con.WS_SYSMENU, 20, 20, 50, 50, 0, 0, 0, None)
def Track(self):
self.CreateInvisibleWindow()
pos = win32gui.GetCursorPos()
win32gui.TrackPopupMenu(self.mainmenu, win32con.TPM_LEFTALIGN, pos[0], pos[1], 0, self.hwnd, None)
win32gui.PumpWaitingMessages()
win32gui.DestroyWindow(self.hwnd)
win32gui.UnregisterClass(self.wc.lpszClassName, None)
return self.itemhandlers[self.pickedmenuid]
def AppendSubMenu(self, parent, string):
hSubMenu = win32gui.CreatePopupMenu()
win32gui.AppendMenu( parent, win32con.MF_STRING|win32con.MF_POPUP, hSubMenu, string)
return hSubMenu;
def AppendMenu(self, parent, string, handler):
self.idcount = self.idcount + 1
self.itemhandlers.append(handler)
return win32gui.AppendMenu( parent, win32con.MF_STRING, 1024 + self.idcount, string)
def AppendSeparator(self, parent):
return win32gui.AppendMenu( parent, win32con.MF_SEPARATOR, 0, '')
def OnCommand(self, hwnd, msg, wparam, lparam):
self.pickedmenuid = wparam - 1024
def XSILoadPlugin( in_reg ):
in_reg.Author = "Reinhard Claus"
in_reg.Name = "pyXPOPPlugin"
in_reg.Major = 1
in_reg.Minor = 0
in_reg.RegisterCommand("XPOP","XPOP")
return 1
def XPOP_Execute( ):
return win32com.server.util.wrap( xpop() )
def XPOP_Init( in_ctxt ):
oCmd = in_ctxt.Source
oCmd.ReturnValue = 1
return 1
def XSIUnloadPlugin( in_reg ):
strPluginName = in_reg.Name
return 1
Posted: 02 Sep 2010, 21:07
by Hirazi Blue
Okay, I finally got around to test this & it seems to work. Must dig a bit deeper, before I can say anything more, but at the moment I really haven't got the time. Sorry.
It seems that while creating a custom command the handler function in your example needs to live outside of the execute callback otherwise strange things happen.
How is this "different" for the user from the "
xPopMenu" for Python by Patrick Boucher?
Posted: 02 Sep 2010, 22:06
by rray
Thank you, Hirazi for your time. No obligations here ;)
Hm I'm having a slow day, I didn't understand what you meant be living outside the execute callback. Does it mean that it can not be implemented inside the plugin code? Or just not as a functions-inside-the-execute-function?
There's no difference really to Patrick Boucher's extension except that it's just simpler implementation because it doesn't use the original XPOP, and that it (hopefully) runs on linux. Also it is extendable (also hopefully).
Posted: 02 Sep 2010, 22:12
by Hirazi Blue
And this is obviously me having a bad day, because you cannot do this period AFAIK.
But it took way too much time before I noticed,
after simply copy/pasting your example into a custom command
and wondering what the error message was trying to tell me.
That's why I mentioned it!
A little more documentation would have been nice, though...
I looked at the original xPop site and felt naturally something was missing (=Python
Posted: 02 Sep 2010, 22:32
by rray
Ah that's good to hear no 2nd file has to be used. It's usually not possible to make functions in a function, only as inline functions, something like (JScript)
set_timeout(6minutes, function() { alert("you egg is ready to consume"); })
I'll create some docs for the finished Xpop 2.0, and also try to make a little download library of ready-to-use popups.
Python is neat, with Softimage there seems to be a collection of addititonal libraries distributed (like the win32gui I used). Just beginning to explore these.
Posted: 03 Sep 2010, 10:05
by Hirazi Blue
Forgot to mention this yesterday (and I'm not sure if this is xPop-related or a mere Softimage quirk), but your example code creates an entry to open a new scene. This prompts you with the normal "want to save? yes | no | cancel" dialog. When you however press "cancel" this throws an error.
Again, not sure if this standard Softimage behavior (as I have never started a new scene from scripting before), but I wanted to mention it nonetheless...
Posted: 03 Sep 2010, 15:49
by rray
This looks like a bug with python, even if you type Application.NewScene() in the command line you get that
Doing some custom draw tests right now after having spent too much time in the sun
Posted: 06 Sep 2010, 00:16
by rray
Ok rc1
some custom drawing code finished
New features:
* icon support (For now only a fixed set of icons. They are installed with the xsiaddon)
* "section headers" with custom background color (these can't be selected)
* possible to set a vertical offset for the whole menu, so the mouse cursor is on a specified menu item when it's activated
* example popup menu commands in python, VBS and js
* accelerator keys work now
* greyed out menu items
* (checkboxes can be created with the "Ok" icon .. but the logic has to be done manually)
Here's a list of the icons, add a menu item with icon like this (JS)
item = p.AddItem( sub2, "Pepsi Light", "handler(2)");
p.SetIcon( item, "Flag" );
The JS example command demonstrates some menu logic like radio buttons/toggle checkboxes/enable menu item. VBS and python example only show basic menu
(from
Axialis Studios)
download
here
