It is currently 23 May 2013, 19:41
Post new topic Reply to topic  [ 32 posts ]  Go to page Previous  1, 2, 3, 4  Next
Author Message
 Post subject: Re: GoSoftimageLite - Zbrush-Softimage exchange [UPDATE!!!!]
PostPosted: 27 Oct 2010, 23:00
Offline
hi Nizar
are you sur to use the right GoSoftLite.zsc if yes
I suggest you
uninstall the plug in softimage and delete the GoSoftimageLiteAddon foder in you user group or workgroup
delete the GoSoftLite.zsc in Zbrush folder
and start a new installation
may be ???
_________________
'ERROR : 2011 - Unable to write well in English [CLSID\{F123FC55-ABD9-4D7F-9CDD-7F9D61E71FFE}] : %SUMATRAPATH%\ English.dll not found'
Une Méchante Petite Fille
Top
 Profile
PostPosted: 28 Oct 2010, 13:05
Offline
Hi, thanks Zossowosso.
I cancelled and unistall from zbrush and from XSI, repeat all the operation, and now work. But if I try a heavy mesh, XSI crash and stop working (for all the mesh, I must cancel again all and reinstall).
_________________
Hi, I'm Pamela Anderson and I use Softimage for all my modelling, animation and rendering needs
Top
 Profile
PostPosted: 28 Oct 2010, 16:43
Offline
Zbrush works well without error messages?
Top
 Profile
PostPosted: 28 Oct 2010, 16:45
Offline
What is heavy mesh? How much polygons? Actually it uses the builtin OBJ importer, so you may try to import it via the Import OBJ menu in the File menu
Top
 Profile
PostPosted: 28 Oct 2010, 17:06
Offline
mesh is 2.000.000 polygons. It is only a test, actually don't need. If I import like obj it work correctly (xsi can manage it)
No, zbrush don't give any error message
_________________
Top
 Profile
PostPosted: 29 Oct 2010, 08:16
Offline
I'll check it. But the fact is that I call the ObjImport function which is the same as if you just use the File|Import|OBJ menu...
Top
 Profile
PostPosted: 29 Oct 2010, 22:22
Offline
hi Nizar
for fun export from Zbrush your mesh 2.000.000 polygons normally in obj format and re-import the mesh in obj format in SI to see
_________________
Top
 Profile
PostPosted: 01 Nov 2010, 16:13
Offline
It work correctly, only if I use GoSoftlite had problem. I don't know why
_________________
Top
 Profile
PostPosted: 01 Nov 2010, 17:53
Offline
As a last try. please zip the GoSoft addon folde, and send me to check. I need just the addon you insalled
Top
 Profile
PostPosted: 02 Nov 2010, 12:22
Offline
Hi, thanks so much :)
Do you mean the folder in XSI directory? Can attached file in a simple PM?
_________________
Top
 Profile
Search for:
Jump to:
