Another Softimage to Mitsuba exporter
Mitsuba ExporterAuthor: Shekn @si-community
v0.7.2 updated Apr 4th 2015. This plugin is called Mitsuba and Softimage synchronizer (shortly MaSs). I start to develop it for understanding how the Mitsuba renderer works. So, some tool for export scenes needed. Of course, there are some other exporters from Softimage to Mitsuba. One of them here. I try to understand how it works, but then decide to create my one exporter with Python and GUI.
The latest update includes the abilty to render volumes. For that purpose, the package includes ICE compounds that create 3D-grids which can be manipulated further in ICE, exported with the 'Store VOL' compound, then rendered using Mitsuba. Supports rendering of OpenVDB volumes through Oleg Bliznuk's OpenVDB ICE package. More in the si-community thread.
Slava Shumikhin made a fork of an older version of Shekn's plugin available here on github.
local backup: MaSs plugin 0.7.2 package.zip Mitsuba 0.5.0 x64 Win.zip (compatible version of Mitsuba)
nDman
Re: Another Softimage to Mitsuba exporter
Post by nDman » 01 Apr 2015, 16:07
Ok, i did second try to install it. PyQt installed perfectly and it works well (On SI-2013). But now there is a problem at export mesh for render!
#   File "<Script Block 2>", line 1944, in MaSs_Render_OnClicked
#     ActOneFrame(int(frame))
#   File "<Script Block 2>", line 1948, in ActOneFrame
#     scenePath = ExportXML(f, oProp)
#   File "<Script Block 2>", line 2046, in ExportXML
#     oProp.Parameters("clamping").Value, oProp.Parameters("useColorAttribute").Value, frameNumber, oProp.Parameters("lastTime").Value))
#   File "C:\Users\Saeed\Autodesk\Softimage_2013_SP1\Addons\MaSs\Application\Plugins\MaSsXML.py", line 234, in GenerateXMLScene
#     root.append(GenerateMeshSegment(mesh, shouldExport, exportPath, exportType))
#   File "C:\Users\Saeed\Autodesk\Softimage_2013_SP1\Addons\MaSs\Application\Plugins\MaSsXML.py", line 2854, in GenerateMeshSegment
#     MeshShouldExport(mesh, exportPath, exportType)
#   File "C:\Users\Saeed\Autodesk\Softimage_2013_SP1\Addons\MaSs\Application\Plugins\MaSsXML.py", line 2734, in MeshShouldExport
#     ap.ExportPly(True, mesh, exportPath, mesh.FullName + ".ply")
#   File "C:\Python27\lib\site-packages\win32com\client\dynamic.py", line 516, in __getattr__
#     raise AttributeError("%s.%s" % (self._username_, attr))
# AttributeError: <unknown>.ExportPly
#  - [line 2045 in C:\Users\Saeed\Autodesk\Softimage_2013_SP1\Addons\MaSs\Application\Plugins\MaSsPlugin.py]
# ERROR : Property Page Script Logic Error (Python ActiveX Scripting Engine)
# ERROR :    [2043] oProp.Parameters("maxPasses").Value, oProp.Parameters("bidirectional").Value, oProp.Parameters("luminanceSamples").Value, oProp.Parameters("twoStage").Value, oProp.Parameters("pLarge").Value,
# ERROR :    [2044] oProp.Parameters("bidirectionalMutation").Value, oProp.Parameters("lensPerturbation").Value, oProp.Parameters("multiChainPerturbation").Value, oProp.Parameters("causticPerturbation").Value, oProp.Parameters("manifoldPerturbation").Value, oProp.Parameters("lambda").Value,
# ERROR :   >[2045] oProp.Parameters("numChains").Value, oProp.Parameters("maxChains").Value, oProp.Parameters("chainLength").Value, oProp.Parameters("bruteForce").Value, oProp.Parameters("granularityP").Value, oProp.Parameters("shadowMapResolution").Value,
# ERROR :    [2046] oProp.Parameters("clamping").Value, oProp.Parameters("useColorAttribute").Value, frameNumber, oProp.Parameters("lastTime").Value))
# ERROR :    [2047] 	file.close()
# ERROR :    [2048]
It seems export dll file compiled for higher version.
Angel 07
Post by Angel 07 » 04 Apr 2015, 15:38
This version should work: https://dl.dropboxusercontent.com/u/114 ... 2.xsiaddon
There are some errors and XSI crushes (because of some differences in API), when I tried to use the plugin in SI 2013. But this version works correctly.
nDman
Post by nDman » 05 Apr 2015, 15:52
Angel 07 wrote:This version should work: https://dl.dropboxusercontent.com/u/114 ... 2.xsiaddon
Cool, thanks for this. It works partially. It exports correctly and i can open and render the scene file by Mitsuba GUI program.
But inside SI it won't render and it stays in Rendering... state.
Sorry, i just reporting problems. If it's time consuming to make it work on SI-2013, forget about it ;) I will use Mitsuba GUI to render :)
Angel 07
Post by Angel 07 » 09 Apr 2015, 16:24
I did some tests, and it seems that the problem in external Python. I have Python 2.7 in my system, and when I tried to use it in SI2013 some errors appear during the export process. But with built-in SI2013 Python export works perfect. When I tried to use Python from SI2015 as external Python for SI2013 all works correct. So, you can try to use the Python distributive from this link: https://dl.dropboxusercontent.com/u/114 ... SI2015.zip
This is not default Python folder from SI2015, but additionally it contains only PyQt4 and Gear modules.
Post Reply
Users browsing this forum: No registered users and 65 guests
