Does it works with python 2.6 ?
because there might be some problem with 2.7 version (?)
http://www.si-community.com/community/v ... lit=python
QuickLauncher
Quicklauncher V0.1.3
Updated Dec 18th 2013 Today I want to share a tool I've been using for a while, it's a simple menu to search
and launch softimage commands and scripts (you can set the script directory on the
preferences). In order to make it fast I'm caching the commands and script paths (just
the paths, the script itself is loaded on runtime), so if you add a new script file
or connect/disconnect workgroups please make sure that the cache is reloaded (there's
a command just for that) and everything should be fine. The menu requires PyQtForSoftimage and it's avalaible here. Give it a try and let me know what you think :-) Cheers!
video demo. Along with the recent update that introduces the concept of »script packages«, Cesar also shares a useful set of premade script packages including: animation, filter, misc, modeling, primitives, programming, rigging. Go here to browse/download the script packages repository on github.
local backup: quicklauncher-master.zip quicklauncher_packages-develop.zip (repository snapshots from Feb 21st 2014)
author site: http://www.cesarsaez.me / download: ..launcher-v013.html / vimeo channel / repository @github / si-community thread
- csaez
- Skype: csaezmargotta
- Contact:
Re: QuickLauncher
The menu only list softimage commands with default values or without arguments, other than that is difficult mimic all the possibilities.gaboraa wrote:Thanks it is installed now but I couldn't call extrude bevel and other polygonal mesh operators and I wonder if I did something wrong
As workaround you can copy the bevel/extrude/whatever code and save it on the script folder, that way you can easily extend the system to fit your needs.
file: bevel.py
Application.ApplyTopoOp("BevelComponent")
Application.ApplyTopoOp("DisconnectComponent")
No, pyqt for softimage requires python 2.7eben wrote:Does it works with python 2.6 ?
Hope this helps!
Re: QuickLauncher
The problem is I'm running Py3.3 alongside 2.7, and I'm trying to figure out a way to have XSI only run off the 2.7 install. To be fair, I also haven't devoted a lot of time to fixing it -_-"csaez wrote:In order to run pyqt you will need:
- Python 2.7
- Python for Windows extensions (aka pywin)
- PyQt
- PyQtForSoftimage
- Make sure that softimage is using the system python (there's a preference for that).
Seems like a lot of trouble but pyqt worth it.
Cheers!
Re: QuickLauncher
Looking great. Do you have any ETA on RigLab by the way? It also looks fabulus!
Portfolio / Blog
http://www.nuverian.net
- csaez
- Contact:
Re: QuickLauncher
Hey,
Thanks nuverian, I have to add a couple of features and test it better before the first release, I hope to be back with news in a couple of weeks (fingers crossed).
BTW, will be opensource too
Cheers!
Cheers!
Re: QuickLauncher
Real happy to hear that, looks like an awesome rigging toolset!csaez wrote:Hey,
Cheers!
- csaez
- Contact:
Re: QuickLauncher
Hi guys,
QuickLauncher has been updated adding support for script packages (I also uploaded my own scripts to github in case you need some samples).
https://github.com/csaez/quicklauncher
https://github.com/csaez/quicklauncher_packages
There is also a quick overview on vimeo... I know, my English is not very good, but I'm doing my best.
https://vimeo.com/82227469
Cheers!
Cheers!
Re: QuickLauncher
It looks sexy ! Nice job ! I'll try it as soon as I can get some free time and find out how to make PyQt work here
Thanks for sharing.
Thanks for sharing.
M.Yara
Users browsing this forum: No registered users and 34 guests
