Page 3 of 5
Re: PolyMesh Duplicator v1.1
Posted: 14 Nov 2009, 15:42
by wireframex
Like I told you before :
I need to remove PolyMeshDuplicator.x86.dll
from : c:\Users\xxxxxxx\Softimage\XSI_7.01\Addons\PolyMeshDuplicator\Application\Plugins\
If not it doesn't work at all
Phil
Posted: 14 Nov 2009, 15:46
by nassosy
So be it then.
In my XSI 7.01 x64 winXP, it works without problems though.
Posted: 14 Nov 2009, 15:59
by wireframex
I'm waiting for the 2010 upgrade.
I will post here if I had the same pb. Maybe windows 7 x64 produce some pb with XSI 7.01 x64 and x32.dll
Posted: 15 Nov 2009, 00:15
by wireframex
Still Playing with PolyMeshDuplicator
I don't understand why a big object is created from the original object who is duplicated ?
How to remove it ?
Here the big sphere is attached to the sphere_copies
Phil
Posted: 15 Nov 2009, 00:23
by nassosy
Each duplicate uses the SRT/Transform matrix of the particle whose ID matches its CopyID
If no particle exists, the SRT of the duplicate is random/undefined (you will usually get garbage).
So always make sure there are as many particles as duplicates
When the # of (born) Particles >= # of Duplicates, the large object will disappear
Posted: 15 Nov 2009, 00:26
by nassosy
You can always use Particle instancing instead of PolyMeshDuplicator ;)
Posted: 15 Nov 2009, 00:30
by wireframex
Ok thanks for your light speed answer
Posted: 16 Nov 2009, 20:54
by Squizmek
hey nassosy,
do you think it would be possible to take a group of instancing meshes instead of a single mesh that gets duplicated? This would be really awesome to get an exact copy of the pointcloud as geometry!
Posted: 16 Nov 2009, 21:03
by nassosy
Squizmek wrote:hey nassosy,
I don't understand the question.
Posted: 17 Nov 2009, 01:07
by Squizmek
nassosy wrote:Squizmek wrote:hey nassosy,
Let me show you with a screenshot...
What I mean is: instead of using a single mesh as instancing shape, you can use a group and randomly pick the meshes for instancing. The problem is that with your plugin I can only select the cube, sphere or cylinder to create a polymesh, but not the whole group.
Posted: 17 Nov 2009, 01:22
by nassosy
First of all the plugin doesn't instance, it duplicates (makes extra copies independent of the original)
and it operates on a single PolyMesh at a time.
if you want random instancing of groups, ICE already has this functionality built-in
The source code is included with the plugin,
it can certainly be done if you have time on your hands
which i don't at the moment.
if you want to modify it, be my guest
Posted: 17 Nov 2009, 08:35
by Letterbox
Thank you again nassosy
Posted: 17 Nov 2009, 14:31
by Squizmek
Yes, ICE makes instances, and your plugin makes duplicates. If I wanted instances I wouldn't have posted here.
Posted: 01 Dec 2009, 20:48
by Squizmek
I just wrote a tutorial that also makes use of this plugin.
http://feathertools.michael-buettner.co ... cloth.html
edit: I "tagged" your link (inbetween URL-Tags) - why? look here - HB
Re: PolyMesh Duplicator v1.2.1
Posted: 15 Feb 2010, 08:36
by satyajit
Hi nassosy,
I was trying your wondeful plugin. One question. Is there any way to copy UV data while using the plugin to duplicate. Has anybody else tried this?
Posted: 15 Feb 2010, 12:55
by nassosy
Duplicate,
use GATOR to transfer attributes,
optionally freeze the operator stack.
then move the duplicates
