Page 3 of 5
Re: PolyMesh Duplicator v1.1
Posted: 14 Nov 2009, 13:56
by nassosy
It either couldn't load the plugin,
or couldn't load the ICE compound.
in the later case, open the ICE tree
open the Preset Manager and update the list
by pressing the recycle button
Posted: 14 Nov 2009, 13:57
by wireframex
Sorry nothing more and nothing in the scriptlog file ...
Posted: 14 Nov 2009, 13:58
by wireframex
nassosy wrote:It either couldn't load the plugin,
ok I have a look to this
Posted: 14 Nov 2009, 14:02
by nassosy
or the previous line?
error messages usually look like this:
' ERROR : 21000 - Unspecified failure - [line 90 in C:\users\Administrator\Softimage\XSI_7.01\Addons\PolyMeshDuplicator\Application\Plugins\ApplyPolyMeshDuplicator.vbs]
' ERROR : 21000-CUST-ApplyPolyMeshDuplicator - Unspecified failure
Posted: 14 Nov 2009, 14:22
by wireframex
I don't have this sort of error message ...
After some unspecified failure the compound loaded :
Phil
EDIT : be back after lunch ...
Posted: 14 Nov 2009, 14:25
by nassosy
it works then
Posted: 14 Nov 2009, 15:15
by wireframex
In fact :
1) Install the xxx.xsiaddon file
2) delete the x32 or x64 dll depends of the software u use
3) now enjoy
Thanks a lot
Phil
EDIT : Don't know why I had pb with the unspecified failure
Posted: 14 Nov 2009, 15:18
by nassosy
The whole point of me asking you so many questions
was to see if it works WITHOUT having to delete anything
well, does it? (even if it gives you error messages)
Posted: 14 Nov 2009, 15:42
by wireframex
Like I told you before :
I need to remove PolyMeshDuplicator.x86.dll
from : c:\Users\xxxxxxx\Softimage\XSI_7.01\Addons\PolyMeshDuplicator\Application\Plugins\
If not it doesn't work at all
Phil
Posted: 14 Nov 2009, 15:46
by nassosy
So be it then.
In my XSI 7.01 x64 winXP, it works without problems though.
Posted: 14 Nov 2009, 15:59
by wireframex
I'm waiting for the 2010 upgrade.
I will post here if I had the same pb. Maybe windows 7 x64 produce some pb with XSI 7.01 x64 and x32.dll
Posted: 15 Nov 2009, 00:15
by wireframex
Still Playing with PolyMeshDuplicator
I don't understand why a big object is created from the original object who is duplicated ?
How to remove it ?
Here the big sphere is attached to the sphere_copies
Phil
Posted: 15 Nov 2009, 00:23
by nassosy
Each duplicate uses the SRT/Transform matrix of the particle whose ID matches its CopyID
If no particle exists, the SRT of the duplicate is random/undefined (you will usually get garbage).
So always make sure there are as many particles as duplicates
When the # of (born) Particles >= # of Duplicates, the large object will disappear
Posted: 15 Nov 2009, 00:26
by nassosy
You can always use Particle instancing instead of PolyMeshDuplicator ;)
Posted: 15 Nov 2009, 00:30
by wireframex
Ok thanks for your light speed answer
Posted: 16 Nov 2009, 20:54
by Squizmek
hey nassosy,
do you think it would be possible to take a group of instancing meshes instead of a single mesh that gets duplicated? This would be really awesome to get an exact copy of the pointcloud as geometry!
