Page 4 of 5
Re: Resourcedump
Posted: 18 Sep 2013, 09:22
by caledonian_tartan
Is the scene only for 2014
yes
but i now included the shader and ice compound into the zip file. so you should be able to use it in older versions.
Re: Resourcedump
Posted: 24 Sep 2013, 13:39
a small modification of the "Bezier Movement along Surfaces" compound. unfortunately i can't remember who was the author of this source...
anyway, you can now use the new compound to create strands by/through many surfaces.
Cable through Surfaces.zip
(26.04 KiB) Downloaded 443 times
Re: Resourcedump
Posted: 24 Sep 2013, 15:27
by Bullit
Thanks, also for the non 2014 version.
Re: Resourcedump
Posted: 05 Oct 2013, 23:01
by rray
Nice!! keep them coming!
spherize
Posted: 13 Nov 2013, 12:29
by forton
Deformer that takes a null or group of nulls and pushes the objects points outside the nulls, nulls can also be rotated and scaled, can be useful for "muscle type" deformation or correcting volumes in characters etc.
Scenes.zip
(129.33 KiB) Downloaded 332 times
Re: Resourcedump
Posted: 11 Dec 2013, 15:19
hello
i'm trying to get used to arrays. so after playing around a bit i got a "4 point 3d corner pin".
4 Point Corner Pin.xsicompound
(55.04 KiB) Downloaded 309 times
the downside is:
- only works for grids.
- you need to match the Resolution of the Grid and ICE compound manually. (is it really impossible to get or set the resolution from the geometry operator? i guess so...)
Re: Resourcedump
Posted: 11 Dec 2013, 20:02
by mattmos
You can't just drag the green widget in to the ice tree? It works for me here, can get .subdivu and .subdivv data.
Thanks for sharing btw!
Edit: I'm using 2014sp2
Re: Resourcedump
Posted: 12 Dec 2013, 08:31
that's great news!
i remember i did so too in the past. but i doesn't let me now... (SI2014 SP1)
good to know, thank you!
EDIT: "this.geom.subdivu"/"this.geom.subdivv" is the way to go with a get data!
shallow water simulation coupled with lagoa multiphysics
Posted: 21 Dec 2013, 02:20
by gustavoeb
For those in the need to simulate SIMPLE water interactions FAST this is a shallow (2d) water simulator coupled with Lagoa, so it does not look toooooo cheap. It cant do curls and rolling waves, but it will spit some Lagoa particles for your viewing pleasure :D
It served quite well on a little student short, so maybe it can help others. I would love to keep working in it but no time for it, so here it goes:
https://dl.dropboxusercontent.com/u/39280733/mFlow.scn
KEEP IN MIND:
1. Anything that says "Energy Conservation" is actually just a multiplier of some energy transport. So it is like other multipliers, but, if you go over 1 energy will increase instead of dissipate causing a chain reaction that can blow up the entire matrix. So use it carefully. Turn 2-way coupling off if you really need to cheat physics.
2. Use it as is, or hack it at will... I cant support it :p
PS:
There are other things that could be done to it. It could be made more physically correct. Motion transport could have more meaningful parameters like say, viscosity. Also maybe someone could implement a bottom attribute so we could calculate the actual volume and preserve it accordingly... one can dream :ymdaydream:
Re: Resourcedump
Posted: 14 Jan 2014, 17:03
by rray
Thanks all for keeping it up!
>>>>>>> This is a patch for a factory file - use at your own risk!
This one allows custom ICE operators (those Peferences->Custom->ICEOperators) to be applied on each selected item instead of on just one selected item (default behavior)
2014SP1
C:\Program Files\Autodesk\Softimage 2014 SP1\Addons\ICEUserTools\Application\Plugins\ICEUserTools.vbs
(line 596)
function OperatorClicked(in_ctxt)
	on error resume next
	oString = in_ctxt.source
	for each o in selection
		applyICEOp oString, o
	next
end function
Re: Resourcedump
Posted: 14 Jan 2014, 17:28
sounds cool! thanks rray.
can you give an example of when or why to use those "ICEOperators" from preferences?
Re: Resourcedump
Posted: 14 Jan 2014, 18:01
by rray
It's just a convenience feature. When you have an ICE tree that you want to apply to another object, just compound it up, register it by exporting, and enter the compound name in the preferences. You can just select an object, click the menu and the compound get applied to the object.
Otherwise you'd have to go through the whole create new ICE tree--->drag an drop node-->connect to execute port, deal.
This is all built in, what the patch does is just allow to apply the compound to several objects at once using the same menu.
Re: Resourcedump
Posted: 16 Apr 2014, 01:46
by Tekano
aaand it took a while to find this thread. it was in plugins! anyway , always nice to resurect it again, here is a quick setup demo scene example of rigid body (vorlex) simulated with verlet for some ICE on ICE interplay.
from a request on the mailing list.
scene file attached v2013
Re: Resourcedump
Posted: 17 Apr 2014, 01:19
by Bullit
That looks very good.
Re: Resourcedump
Posted: 17 Jul 2014, 22:30
by Tekano
a vimeo request, posting rar compressed (so it fits under 256k) scene file below.
some fancy fibbonnaci rotation effect or other
Re: Resourcedump
Posted: 23 Jul 2014, 22:10
by Bullit
Thanks.
