Image I\O From ICE
Image I/O from ICEAuthor: Oleg Bliznuk
Originally developed for testing his Implosia FX toolset, Mr. Core recently released these compounds that allow to import and export image (.BMP/.TIFF/.PNG/.JPG) and mesh files (.OBJ, UV not yet supported) within ICE.
For image handling, this package includes the Build PCloud from Image compound that converts the output array from the IFX Read Image node into a pointcloud, which can be further modified by ICE and then written back to an image file through the factory build array from set node plugged into IFX Write Image. This allows a PixelParticles-like workflow (See PixelParticles description further below) for doing for example image manipulations inside ICE.
The local backup archive contains all files collected from the si-community thread (see below) including some additional compounds by Fabricio Chamon which handle file name/format string conversions. To install, copy the .xsicompound files into the Data/Compounds folder of the USER or a workgroup/addon directory. The .dll file goes into the Plugins subfolder — demo scene file is included.
Related plugins: Pixel Particles, Image ICE Node
local backup: ImageIO_packed_1.0.zip
Tekano
Re: Image I\O From ICE
Post by Tekano » 19 Dec 2011, 00:11
hang on a minute.. this means we can render image files using ICE, right? and can build the array of particles out of what a camera would see and write to an image sequence? who needs Mental Ray ?! ;)
blaxxun
Contact:
Post by blaxxun » 25 Aug 2014, 11:26
Hello,
Its been a while on this thread, but i wonder if there is a way to make this plugin work with
Softimage 2014 SP2.
Softimage is crashing as soon as i plug the "IFX Read Image Node" into the "Generate 3D Grid Node"
Since iam researching on how to do a Terrain LOD i think that this plugin would be really important.
Post by Hirazi Blue » 25 Aug 2014, 17:58
Sorry, but someone has to ask: did you install the prerequisite Visual C++ runtime.
I can't test this on 2014SP2 as I never installed that specific SP,
but I cannot reproduce the crash you describe on either 2014SP1 nor 2015.
Where does your ICE Tree "live"? On an empty PointCloud, where I believe it should?
blaxxun
Contact:
Post by blaxxun » 26 Aug 2014, 01:58
Hello,
Yes, i have
Microsoft Visual C++ 2010 x64 Redistributable v10.0.40219
Microsoft Visual C++ 2010 x64 Runtime v10.0.40219
Microsoft Visual C++ 2010 x86 Redistributable v10.0.40219
Microsoft Visual C++ 2010 x86 Runtime v10.0.40219
installed.
Also 2012 and 2013.
Also i created an empty PointCloud with ICE Tree.
So the ICE Tree lives IN the PointCloud.
When i check the link provided i end up with an older version of "Microsoft Visual C++ 2010 x64 Redistributable"
which i dont install since i have a newer one already installed.
Post by Hirazi Blue » 26 Aug 2014, 10:51
Try installing the older one also. It doesn't make sense, but from my own experience IIRC it sometimes does help.
PS I don't say that IS "the" problem, it may however something you can relatively easily rule out... ;)
Post Reply
Users browsing this forum: No registered users and 14 guests
