Sun position plugin
Re: Sun position plugin
Hi, I own 2010 and never upgraded so I was trying to use the "unofficial" kinematics part of that version to rotate the null like the plugin did.
BUT I just couldn't get it to work. It seemed like I needed too many decimal places and ICE didn't seem to go to that degree. I could upload it (if I can find it) and you could see if you can make it work, but I've pretty much given up using SI for Archviz. I use Sketchup and Octane now.
A quick preview.
Changes to make are a matrix output and some fixed input locations...
face
face
Amazing!
Could you explain a little bit about coding the SunPositionCore Node?
SI 2015 @ WIN7-64
Which detail on coding, the ICE-stuff itself or the sun algorithm for the position calculation?
face
face
well i was interested in coding of custom ice nodes.
never done this.
never done this.
SI 2015 @ WIN7-64
In the SDK are many examples where you can learn a lot.
Here the next try...
face
face
Two new previews on Vimeo.
I think the plugin should be done now...
face
face
Ok, here is the ICE version for Softimage 2011- Windows x64.
It looks a little bit different from the videos above, the result is the same.
How it works and how you can use it, is shown in the video below.
Hope you have fun with it ;)
face
face
- Attachments
- SunPosition_x64.zip
- (146.26 KiB) Downloaded 249 times
very cool!
I'll have a look asap, it will a nice tool for archviz timelaps renders ;)
Thank you Face, and great work. You can't imagine how great addition to my tools is this for me.
Bravo to make this available. Thank you !
Thanks, Face, for the great addon!
I'm too stupid to figure the basic setup, though. Could you please demonstrate the necessary steps?
Create a pointcloud, add a simulated ICE tree, add the "sun position frame" node, ok.
Now what? Do I need to add a point first? Nothing's happening when I move the time slider.
Thanks and best regards,
Eugen
Eugen
I will upload a simple test scene when i´m back from work, in about 10hrs ;)
face
face
Ok, here is a simple test scene which shows how to drive the position of a point light, with the calculated sun position from the plugin.
face
face
- Attachments
- SunPosition_Scene.zip
- For Softimage 2013
- (132.67 KiB) Downloaded 194 times
Users browsing this forum: No registered users and 51 guests
