Ice workflow utils
ICE Workflow utilities
context menus for common ice workflow tasks, such as getting/setting data and data
type initialization.
Video documentation available here
Usage: right click any set data input port > get this data or: right click any get data node > set this data or: right click any node > get reference data (get data stored at all reference inputs) or: right click any set data input port > Init as... > [choose datatype from submenu]
Note from user face from the si-community thread: To get this plugin running on 2013, open the addon with a texteditor and change all descriptions like this. From: description="C:UsersFabricioAutodeskSoftimage_2012AddonsICE_WorkflowUtils etview_ICE_WorkflowUtils.txt" To: description="netview_ICE_WorkflowUtils.txt"
Related plugins: Quickly insert and remove ICE pass through nodes, Navigate ICE Tree (with Hotkeys), Copying ICE nodes with input connections
local backup: ICE_WorkflowUtils.xsiaddon
Ice workflow utils
Context menus for common ice workflow tasks, such as getting/setting data and data type initialization.
Get addon from: HERE
installation:
- drag'n'drop link above to softimage window (or install it from menu file > add-on > install)
- restart softimage
usage:
a) rick click any set data input port > get this data
b) rick click any get data node > set this data
c) rick click any node > get reference data (get data stored at all reference inputs)
d) rick click any set data input port > Init as... > [choose datatype from submenu]
installation:
- restart softimage
usage:
Re: Ice workflow utils
I love the idea of right-clicking on an input and having a "get this data" option - a very elegant and brilliantly obvious idea. Thanks for sharing!
Yes, it saves many time, big thanks!
glad to help! =)
It has increased my productivity by around 30%.
Even though there's no way control node's position on the icetree viewer, I tend to compound as much as possible, so it still proved to be very useful and now it's something I can't live without anymore.
That shows how much time one expends just typing and cltr+c/ctrl+v'ing in the ice world.
Now I can focus 100% of the time on the logic and forget about typing.
description="C:\Users\Fabricio\Autodesk\Softimage_2012\Addons\ICE_WorkflowUtils\netview_ICE_WorkflowUtils.txt"
To:
face
To:
face
it's a great helper!
unfortunately i get this error from 2014 SP1:
' ERROR : 2268 - This function is missing:
' <function: ICE_Init_Data_Execute>
' <path: \\3d1-7p64\3d1_share\__SI__\SI_SHARE\SI2014_WORKGROUP\Addons\ICE_WorkflowUtils\Application\Plugins\ICE Init Data Plugin.js>
SI 2015 @ WIN7-64
- xsisupport
I'd ignore that, it's harmless. Or just edit that .js and comment out the RegisterCommand call.caledonian_tartan wrote:it's a great helper!
' ERROR : 2268 - This function is missing: ' <function: ICE_Init_Data_Execute> ' <path: \\3d1-7p64\3d1_share\__SI__\SI_SHARE\SI2014_WORKGROUP\Addons\ICE_WorkflowUtils\Application\Plugins\ICE Init Data Plugin.js>
worked. thanks!just edit that .js and comment out the RegisterCommand call.
SI 2015 @ WIN7-64
