RCTools updates
RcTools 5.3
Updated April 2013 — 5.3's main new feature TopoClipboard lets you copy map data from a point/edge/polygon/sample selection and paste it somewhere
else one the same, or a different mesh into a selection that has the same »shape«
as the first selection. Works also for complete selections which makes sense when
pasting across two meshes that have the same topology, but differing point orders.
TopoClipboard transfers: Vertex Colors UVs Envelope weights (with a remapping option) weight maps tangents point positions (local »shape« of the selected area). Works across different
maps of the same type and across scenes inside one instance of Softimage. Other new
features are a topology based mirror/flip selection and a couple of new settings for
the custom filters like point position compare components, edge on UV border, edge
orientation.
The RCTools plug-in is a collection of workflow helpers and filters for Softimage. The supplied popup menu (Script command »rcToolsPopup«) gives you quick access to all the tools. [..] List of features: Peek (Align camera along selected edge/facing selection @90°;) TopoClipboard Flip Selection Mirror Selection Fill Selection Walk Patterned Loop selections Apply Pattern Customizable Filters (by polyon area, aspect ratio, orientation, edge length, point distance and 30 others) subcomponent clipboard subcomponent clipboard booleans (e.g. Select intersection of current and clipboard selection) Cap holes Repeat
local backup: rcTools.5.3.xsiaddon
Re: RCTools updates
Hi Rork,
it sounds like this would be possible with the random polygon filter followed by the "grow to island" command.
But you'd have use a lower value for "selection propability", like if you aim for 50% of the islands and you have 5 polygons per island, you'd have to use 0,1 (0,5/5)
Cheers,
Ray
Cheers,
Ray
Re: RCTools updates
I'll try to install the addon and see what happens
It would be nice if I can select stuff with this method. Makes my trees a little less static.
cheers,
cheers,
Re: RCTools updates
Cool let me know how it works, (btw using internal "Grow selection" a few times might be faster than the grow to islands command for a high number of islands.)
Re: RCTools updates
Ha, I was just doing the very same thing to see if it would work (random select/grow to island) while you two were here idly chitchatting
So, I can confirm it does indeed work and does what Rob wants.
Very nice toolset, Rray, thanks!
Re: RCTools updates
yup, does work just fine
me happy
P.S. I used the custom filters: "polygon sides","orientation vector" and "random vector". I quickly select one 'polygon leaf' for the max. derivation, and add the set to the selection. Very cool.
me happy
Re: RCTools updates
Poorly that with new rcTools not work with Plugins that need Xpopmenu (OrenoXPOP)
Re: RCTools updates
Thanks for the Follow-ups!
Ramon, what error message do you see? Couldn't reproduce it here. Double checked for conflicts with other XPOPs. Do you have a newer version of Junki's OrenoXPOPs than the one that's available here? That one uses an old version of XPOP (non python) which shouldn't be affected (theorertically....)
Re: RCTools updates
Hi! Install OrenoXpop10.xsiaddon, I think it is last version
error in OrenoXPop.js in line
var iCmd = DisplayPop(LabelAll,Name,Color);
// ERROR : 2006-CUST-OrenoXPopA - Unexpected failure.
OrenoXPopA();
The same error with other plugin PF_Popup_v1.1
e=DisplayPop (cl_barra& cl_barra& cltxt_Full& c_barra& c_barra& ctxt_Full& d_barra& d_barra& dtxt& expr_barra& expr_barra& exprtxt_Full& Sc_barra& Sc_barra& Sctxt_Full& p_barra& p_barra& Ptxt_Full )
Installed Xpop2.0 but not help! This plugins work with RCtools 4.3
with rctools 4.5 this plugins will die?
OrenoXPopA();
Re: RCTools updates
Ok I think I have an idea now what happened...
PF Popup and orenoXPOP were using the XPOP 2.0 popup plugin that's included with rctools 4.3
In rctools 4.5 this isn't included anymore (it has it's own popup) so by uninstalling rctools 4.3 those plugins stopped working. (It's not an incompatibiliy with 4.5)
Why they don't work when you installed XPOP 2.0 "standalone" can have two reasons:
Maybe it was the wrong version, it's split... (here for 32 bit, here for 64 bit).
Try reinstalling, this would work for Pablo's plugin.
To make the confusion complete, Junki's popup editor uses a version of XPOP2.0 that I don't have anymore (it uses 2 extra parameters for name/color of menu in the call, current one doesn't).
To make it work with XPOP 2.0, you would have to remove these two parameters in the line that produces the error (only for Junki's popup).
(or extract the only popup dll from rctools 4.3)
Re: RCTools updates
Ok! Just copy old rcXPOP.64.dll from 4.3 version to new 4.5 - rcTools\Application\Plugins and it work!
Thanks a lot. rray!
Thanks a lot. rray!
Re: RCTools updates
Reinhard, thanks for the new version - downloading now...
Rob, I used a similar method with jellybeans a while ago (although I bet you could use ICE now!?), it worked a treat. RCtools really speeded things up!
Re: RCTools updates
Unfortunately when I try to use the RC45Popup command, it stops with an unexpected failure.
// ERROR : Object expected - [line 46 in C:\Users\Jester\Autodesk\Softimage_2012_SP1\Addons\rcTools\Application\Plugins\rcPopup45.js]
// ERROR : 2006-CUST-rc45Popup - Unexpected failure.
rc45Popup();
Can you help me?
Szabolcs
rc45Popup();
Can you help me?
Szabolcs
Re: RCTools updates
I suspect something with the Python installation. Do you have Python in the list of available scripting languages when opening a script editor?
Re: RCTools updates
runonce.bat made the python active again, and it works like charm.
Re: RCTools updates
I've had the same thing. The strange part is that it was working fine a couple weeks ago for me but now it's not. I'm not sure what I changed.
Hopefully rray will save us
Re: RCTools updates
Wow, that was faster than I could post! I'll try that. Thanks!!!
Users browsing this forum: No registered users and 20 guests
