RCTools updates
RcTools 5.3
Updated April 2013 — 5.3's main new feature TopoClipboard lets you copy map data from a point/edge/polygon/sample selection and paste it somewhere
else one the same, or a different mesh into a selection that has the same »shape«
as the first selection. Works also for complete selections which makes sense when
pasting across two meshes that have the same topology, but differing point orders.
TopoClipboard transfers: Vertex Colors UVs Envelope weights (with a remapping option) weight maps tangents point positions (local »shape« of the selected area). Works across different
maps of the same type and across scenes inside one instance of Softimage. Other new
features are a topology based mirror/flip selection and a couple of new settings for
the custom filters like point position compare components, edge on UV border, edge
orientation.
The RCTools plug-in is a collection of workflow helpers and filters for Softimage. The supplied popup menu (Script command »rcToolsPopup«) gives you quick access to all the tools. [..] List of features: Peek (Align camera along selected edge/facing selection @90°;) TopoClipboard Flip Selection Mirror Selection Fill Selection Walk Patterned Loop selections Apply Pattern Customizable Filters (by polyon area, aspect ratio, orientation, edge length, point distance and 30 others) subcomponent clipboard subcomponent clipboard booleans (e.g. Select intersection of current and clipboard selection) Cap holes Repeat
local backup: rcTools.5.3.xsiaddon
Re: RCTools updates
Everything works fine. Are there any tools for ring selection?
Re: RCTools updates
Yes, they're in there. Consider using the Softimage built in loop/ring tools also, rctools is just a slightly different workflow, you might prefer the built in workflow.
Loop selection is in there more as a legacy from the first versions, not its main function anymore.
Re: RCTools updates
Another little update probably the last one for a while: Symmetrize
(Re-)symmetrizes a polygon mesh object. Analyses the mesh first, looking for topological "partners", and then symmetrizes their positions. Allows copying from left to right, right to left, left/right average and flip left/right. The same functions exist for bottom/top and front/back. If something was selected, only the selected components will be symmetrized.
Re: RCTools updates
In RCTools, there is XX.XX.XX.XX etc for selected, what about little icons to represent how it will be selected, graphical icons ?
Re: RCTools updates
rray, thanks for the ongoing development of RCTools.
Re: RCTools updates
Looks great! Will have to try it today
Re: RCTools updates
You're welcome Letterbox
ActionArt : great, report any weirdnesses you find
Note the symmetrize fails already when a single part (island) of the mesh has more than 1 symmetry plane. For example heads with eyeballs often won't work because eyeballs (usually) have more than 1 symmetry plane)
I agree this would be prettier, but would require some hours spent writing a custom drawing routine. Not worth it imhoFalam wrote:In RCTools, there is XX.XX.XX.XX etc for selected, what about little icons to represent how it will be selected, graphical icons ?
Re: RCTools updates
Really useful tools ! (I really like "Sharp Edges" selection on Custom Filters )
May I suggest two things :
1) I don't know if that me but I can't loop a pattern on parallel edge (see screenshot below) 2) On the Custom Filter PPG, on the Edge tab, is it possible to add an option for the boudary edges ?
In all cases that a great tool thanks !
Re: RCTools updates
Hi julca
1) loop always goes in the direction of the edge, 'complete all edgerings' (in 'more loop options') does what you're after
2) should work if you use total adjacent polygons option with 'min=1' and 'max=1'
Cheers!
Cheers!
Re: RCTools updates
Hi rray,
1) Cool it works well !
2) Cool it works well again !
Thank you for the clarification !
Re: RCTools updates
Seems like a great plug-in, just started playing with it.
I'm trying to weight map a skirt and I've weighted the outer layer. I was thinking this tool might be good for copying the weights for the inner layer of the skirt, but as copypasteing won't work with clusters, it's a bit hard. Is there a good way to go about doing this, or should I just copy a few polygons at a time?
Sorry if this was a stupid question. And thanks a lot for the plug-in
Re: RCTools updates
Not sure if you need a plugin for that, use GATOR to copy weights over.Jho wrote:Seems like a great plug-in, just started playing with it.
Re: RCTools updates
Oh right. I just thought it would be a hassle to cut a piece of the geometry out and merge it back in. But it was pretty easy once I tried it. Thanks a lot.
Although it would be nice to automate this process somehow. So that I could just paint away and all the weights would be copied to the other side. Anyways, I'm getting off topic. Thanks again.
Re: RCTools updates
Yes when the other geo is close by, and it's in point context, GATOR works great.
If you were to copy/paste from sample context like UVs, GATOR had some issues, at least last time I tried, so I think I'd try topo-clipboard for something like that first.
Re: RCTools updates
Hello !
I have noticed that the "Cap marked hole" command add a point on an open edge selection like this : I write a script for this and which can work with multiple objects at once (which use "rcCapHoles" command of course).
I don't know if you can/want integrate this on your plug-in but it would be nice.
In any case I hope not to hurt you with my suggestions.
Cheers.
set mySelection = createObject ("XSI.Collection")
mySelection.AddItems Application.Selection
set myCollNewPolygon = createObject ("XSI.Collection")
for each currentSel in mySelection
if currentSel.Type = "edgeSubComponent" then
for each currentNestedObj in currentSel.NestedObjects
if currentNestedObj.Type = "primitive" then
set currentObj = currentNestedObj.Parent
set myGeo = currentObj.ActivePrimitive.Geometry
nbPointBefore = myGeo.Points.Count
'logMessage "nbPointBefore = " & nbPointBefore
SelectGeometryComponents currentSel
rcCapHoles
nbPointAfter = myGeo.Points.Count
'logMessage "nbPointAfter = " & nbPointAfter
myPointSelection = ""
for i = nbPointBefore to nbPointAfter - 1
myPointSelection = myPointSelection & ", " & i
next
if nbPointBefore <> nbPointAfter then
ApplyTopoOp "Collapse", currentObj.FullName & ".pnt[" & myPointSelection & "]", siUnspecified, siPersistentOperation
end if
myCollNewPolygon.AddItems Application.Selection
end if
next
end if
next
SelectGeometryComponents myCollNewPolygon
Cheers.
Re: RCTools updates
Oh of course all contributions are welcome! I'll build this in for the next release, maybe I'll wrap the multi select code around some other functions as well.
Cheers julca
Cheers julca
Users browsing this forum: No registered users and 77 guests
