PolyMesh Duplicator v1.2.1
PolyMesh Duplicator
V1.2.1 Nassos' recreation of Guillaume Laforge's addon (see video). Creates multiple procedural copies of a mesh which can be accessed from an ICE
tree. Just like Houdini's Copy/Duplicate SOP. See video tutorial on vimeo, and for more details see the si-community discussion link.
local backup: PolyMeshDuplicator1.2.1.zip
author site: n/a / si-community thread
Re: PolyMesh Duplicator v1.1
when changing the scripts i "cut & pasted" instead of "copying & pasting" some parts
my mistake.
redownload from here please
my mistake.
- Attachments
- PolyMeshDuplicator Addon v1.2.1.rar
- (61.39 KiB) Downloaded 2038 times
thanks!!!! works perfect!
- wireframex
Hi
I can't install this script maybe it is not compatible with 7.01 x64 ?
Phil
Phil
What do you mean you can't install?
Does it give you an error?
Does it's icon in the Plugin Manager have a red triangle?
Does it install and does nothing?
Does it crash 7.01?
What???
Does it crash 7.01?
What???
- wireframex
Sorry,
There is the message from XSI :
The plugin is not compatible with the current platform ...
PolymeshDuplicator installed from Install Add-On menu
XSI 7.01 x64
windows 7 Ultimate x64
RAM 8 Go
Phil
XSI 7.01 x64
RAM 8 Go
Phil
This is weird, since i compiled it with the 7.01 x64 libraries.
on my winxp 64 machine it works fine.
I repacked the addon from inside 7.01 x64
if it still doesn't work
i rar'ed the folder structure of the addon
so just decompress it in your "Addons"
user directory under the name "PolyMeshDuplicator"
and either restart XSI or manually load it.
- Attachments
- PolyMeshDuplicator 1.2.1 - packaged with 7.01.rar
- (40.54 KiB) Downloaded 227 times
- PolyMeshDuplicator 1.2.1 - 7.01 Folders.rar
- (29.6 KiB) Downloaded 236 times
- wireframex
Thanks a lot for your super fast answer.
well same pb here for the 2 solutions :
I have this message :
ERROR : 2360 - This plug-in is not compatible with the current platform and will be ignored:
<path: C:\Users\xxxxxxxx\Softimage\XSI_7.01\Addons\PolyMeshDuplicator\Application\Plugins\PolyMeshDuplicator.x86.dll>
seems it only wants a x64 dll ?
Phil
Phil
the x86 version is not supposed to be compatible with the x64 edition
it is for 32bit XSI.
It should automatically ignore it
well just delete the "PolymeshDuplicator.x86.dll" file
and leave the "PolymeshDuplicator.x64.dll"
- wireframex
Now it works
Thanks a lot
Phil
EDIT : Maybe you need to try to detect typical version of XSI because PolymeshDuplicator.xsiaddon doesn't install for me because of the x32.dll
EDIT2 : Or just do 2 versions of your script x32 and x64
Thanks a lot
Phil
Because if it didn't install you wouldn't get the following error:
which is ok BTW.
XSI is supposed to ignore one of the two ".dll"s and continue loading the other one.
Correct me if i am wrong, but i have the suspicion that you didn't even try the command
after the error msg appeared.
Do the following :
Uninstall the addon,
re-install it,
the error msg will appear (as expected)
create a cube (or whatever primitive)
try the "Modify->Poly. Mesh->PolyMesh Duplicator" command
and tell me if it works.
- wireframex
In fact it did'nt works at all, if I want to use it it tells me :
Unspecified failure
Unspecified failure
could you post the whole line of the error?
it usually prints the line number of the file where it encountered the error
It either couldn't load the plugin,
or couldn't load the ICE compound.
in the later case, open the ICE tree
open the Preset Manager and update the list
by pressing the recycle button
- wireframex
Sorry nothing more and nothing in the scriptlog file ...
- wireframex
ok I have a look to thisnassosy wrote:It either couldn't load the plugin,
or the previous line?
error messages usually look like this:
' ERROR : 21000 - Unspecified failure - [line 90 in C:\users\Administrator\Softimage\XSI_7.01\Addons\PolyMeshDuplicator\Application\Plugins\ApplyPolyMeshDuplicator.vbs]
' ERROR : 21000-CUST-ApplyPolyMeshDuplicator - Unspecified failure
Users browsing this forum: No registered users and 36 guests
