It is currently 25 May 2013, 03:30
Post new topic Reply to topic  [ 161 posts ]  Go to page Previous  1 ... 5, 6, 7, 8, 9, 10, 11 ... 17  Next
Author Message
 Post subject: Re: 3delight tests
PostPosted: 26 May 2011, 09:42
Offline
Thanks for the tips, I've tried them, but no success...seems that 3.0.8 is buggy a bit
Top
 Profile
PostPosted: 26 May 2011, 20:00
Offline
Mathaeus wrote:
now a shameless plug (but somehow I'm not sure how many SI-community visits the Area too :) ) - latest image is on Area front page for a while.
Congrats on that! Well deserved! :D
_________________
WWII Aviation Art - Softimage Style! - http://www.actionart.ca
Top
 Profile
PostPosted: 14 Jun 2011, 10:44
Offline
just as a late question:
what are deep shadow maps?
is it the same like shadow maps, which are in the rendersettings?
_________________
SI 2013 @ WIN7-64
Top
 Profile
PostPosted: 14 Jun 2011, 11:21
Offline
Good job!
Shadow map = 2 color-only shadow map, no transparency
Deep shadow map = Pixar's original "with tranparency" shadow map format (pdf)
Detail shadow map = mental image's version of deep shadow maps
Volume shadow map = Softimage's GUI name for MR detail shadow map
_________________
Image rray.de, a resource site for softimage, updated apr 13th
Top
 Profile
PostPosted: 14 Jun 2011, 11:39
Offline
hey thanks! (and good job too for the area post!)
i don't find a way to activate deep shadow maps in 3delight...
it should be possible, but i don't find something in the docs nor the ppg of 3delights render settings...
using the maps in the shadow maps tab renders for ages...
_________________
SI 2013 @ WIN7-64
Top
 Profile
PostPosted: 14 Jun 2011, 20:09
Offline
you enable the deep shadow maps in the same way as with Mental Ray, in Shadow Map tab of light's PPG. For colored deep shadow map, procedure is:
1: in global render options, under Shadow Maps, enable 'Surface' for shadow map shaders
2: apply a 3delight's 'Hit Mode' property to object or group, set 'Run Material' for Shadow Rays
3: put something into the shadow slot in rendertree, let's say Color_Save_State, or Constant material.
cheers
Top
 Profile
 Post subject: Need help getting started
PostPosted: 15 Jun 2011, 16:02
Offline
I'm really having a hard time getting my head around 3Delight rendering. Are there any tutorials or can someone provide a scene I can study?
Thanks.
Top
 Profile
PostPosted: 15 Jun 2011, 16:09
Offline
There is an older tutorial series made by "Chinny" (Jason Brynford-Jones) from Softimage, but he uses XSI 6.5 and an older version of 3Delight for Softimage as well. Still worth watching as a basic introduction IMHO
_________________
Broken, not stirred...
Top
 Profile
PostPosted: 21 Jul 2011, 02:41
Offline
Mathaeus wrote:
CSG
This is a render-time CSG ( constructive solid geometry, Boolean operations ).
Speaking of CSG... anyone know if there is a trick to getting it to work right, beyond the description in the user manual? When I set up a simple test, with two intersecting spheres, (sphere B has the 3Delight CSG property, set to subtract, and is a child of sphere A), the "cut" surface will only respond to ambient light (no shading), and is controlled by sphere B's material.
I'm using SI 2012 SP1 (64-bit) and 3Delight 3.0.11
-Jim
Top
 Profile
PostPosted: 21 Jul 2011, 11:25
Offline
-Jim
as far as I can recall (didn't played with CSG since this scene), setting XSI geo approx to more than zero, or using a Renderman subdivs ( 'smooth subdivision threshold' on zero), made it to work as expected.
Anyway, here is the thread in 3delight forum, about CSG and related stuff. There is also a link to XSI model I've created for these CSG renders.
cheers
Top
 Profile
Users browsing this forum: No registered users and 4 guests
Search for:
Jump to:
