Loving these examples!
I played with Thea a little, but I didn't understand how I could export rigged characters..
It looks nice! I have so much more to learn!
Softimage and Thea Render
Re: Softimage and Thea Render
Thanks. I'm glad you enjoy them so much.Letterbox wrote:We love, be it a furry character, a splitting cell, a super-moper-upper, or a Christmas globe, the work you do with Thea.
It's nice to add a bit of polish to tests and bring them to life rather than have them vanish into a hard drive forever.
Thankyou.Draise wrote:Loving these examples!
I'm afraid with the current export plugin only transform animation can be transfered. Shape animation is not supported. The walking robot character is made of interlocking discs that are just moved by translation and rotation. No meshes are changing shape.
As for the other stuff I've exported a whole new mesh per frame as a sequence. Each frame mesh is imported to Thea and merged with the previous (copying materials et.c) and then rendered in turn.
just so we are clear... thea render doesn't support deformation motion blur, not that the plugin doesn't support it. ;)
I havn't had much of chance to use Thea lately so it's nice to get back into it.
Time for some abstract, motion-graphic type stuff. This is a quick and simple render of an ICE experiment I did a while ago. There is a little bit of flicker on the black cones which I think is caused by something changing as they grow, not sure what. Nothing to do with Thea.
So,
could you say a bit more about render times, what method you were used (I think there is some interpolated radiosity, beside path tracing). In any case, I think I must have this renderer too
Yeah, all the animations on this thread are path-traced unbiased renders. Thea is not not GPU enhanced (yet) so these are obviously quite slow. The Cone Grow animation was around 30 minutes a frame.Mathaeus wrote:So,
Thea is a Hybrid engine so you can switch to a faster biased setup without changing your light setup or materials if required.
Users browsing this forum: No registered users and 44 guests
