It is currently 23 May 2013, 20:16
Post new topic Reply to topic  [ 46 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
Author Message
 Post subject: Re: StrandTree - Ice Procedural Tree Generator
PostPosted: 29 Apr 2010, 05:58
Offline
Reinhard, thanks for pointing the problem. (in fact I was already expecting some problems like that)
Would you mind sharing the scene or posting a screenshot of the ice tree so that I can repro and try to fix the compound ? Also, great to know about the "first particle" solution for the segment shape problem. =)
Thomas, I also highly recommend you to use ShapeSizeAbsolute if you can go with 2011, but if you can't, try a simple "get distance to object (camera.kine.global.pos)> rescale > set strandsize". This is not 100% correct math, but maybe it can be visually acceptable.
About tree optimization, I'm experimenting with tree obj generated via Andy Nicholas' saverRenderMesh addon coupled with helge's mt_spring addon. On a low res tree this can produce much faster/stiffer sims than verlet integration if all you want is a calm breeze movement. then it can be sent back to the original ice tree via geometry queries.
ps: very nice to see the renders, keep'em coming!
Top
 Profile
PostPosted: 29 Apr 2010, 08:49
Offline
Hey, got a little time to step aside the technicalities and have some fun creating images. The idea is to always try to achieve a different look on next renders! Here's a more stylized childlike/fantasy tree:
File comment: fantasy_tree
the setup is very simple: 3 tree point clouds, one bending to the left, another bending to the right and the third bending to the front (bend strands compound plugged on "execute on emit..." to get the curly feel). Also there's 3 spiral curves and each ice tree uses deform tree by curve. A lattice controls the spirals, so that you can model the trunk flow. Lastly, Emit Leaves with simple sphere shapes, throw a little color and voila!
I found the need of having an ice var that tells if a particle is a leaf in the render tree. So I'll update the Emit Leaves compound to have a "isLeaf" boolean you can use to switch colors/shaders in the rendertree.
let's see how it goes on the next...
Top
 Profile
PostPosted: 29 Apr 2010, 15:21
Offline
Thanks for looking into this. It's a basic tree preset with these settings changed:
Hide Leaves
Branch iterations 9, Num Branches 4
Branch Grow Start 0.775, Branch Spread 20
When a "Modify Value by iteration" ("Value"=21) is connected to "Strand Resoultion", the branch flips.
Thomas, If you can't/don't want to go with ShapeSizeAbsolute, Anto posted a ICE tree image in the Kristinka Hair Tests thread which does the computation (near the end of the thread). Using ShapeSizeAbsolute has some effects on the render, it's difficult to describe. The strands looks less smooth.
The last tree image has a nice style.
_________________
Image rray.de, a resource site for softimage, updated apr 13th
Top
 Profile
PostPosted: 07 May 2010, 00:43
Offline
I was testing instancing. Good thing with trees is that you can hardly see they're all the same as soon as their rotation is randomized
(updated with newer picture)
6.000 instances of the same tree
58.000.000 strand segments
avg RAM usage=2.5GB
_________________
Top
 Profile
PostPosted: 07 May 2010, 16:17
Offline
Very cool Reinhard! I'd add a little tree size/color variance to sum up as well.
Is this mental ray that you used? How are the render times?
My early tests had some 2 or 3 different tree pointclouds in a group, that were random instanced on the forest.
I'll try to make a render and post here also.
Top
 Profile
PostPosted: 07 May 2010, 20:27
Offline
Thanks, Fabricio! I have added varying size now (modified the picture).
It is rendered with mental ray, the render time was about 6 hours (2.2 ghz core 2 duo 4GB ram...need to upgrade if I want leaves)
Used Raytracing mode with a 40-lights lightrig (room for improvement :D)
_________________
Top
 Profile
PostPosted: 09 May 2010, 12:42
Offline
really nice man =) is there any way to convert this into polygons after simulation ?
Top
 Profile
PostPosted: 09 May 2010, 14:59
Offline
hmmm a question !
how you instanced all those trees? with instance shape?
can show a bit of ice tree please? i'm trying to learn
thanks and awesome work, this is really interesting to watch!
Top
 Profile
PostPosted: 09 May 2010, 21:25
Offline
@Theht: yes, you can use Andy Nicholas' SaveRenderMesh addon: http://www.andynicholas.com/?page_id=158
it's a lightmap shader that can export objs out of the tesselated rendertime meshes. you can set the following attributes on the icectree for optimization: self.shapeResolutionU and self.shapeResolutionV (both need to be integers)
@Maximus: it's instance shape, you can instance point clouds too! isn't it nice? =)
Top
 Profile
PostPosted: 10 May 2010, 11:13
Offline
thanks man wokrs great.
Top
 Profile
Users browsing this forum: No registered users and 3 guests
Search for:
Jump to:
