My pleasure! How exactly is your array looks?Eugen wrote: Could you please point out how you do that? I'm a beginner with ICE and already stumbled across this problem.
I'd like to write to the MaterialID attribute using fixed array indices.
Thanks for sharing!!
Procedural Topo Pack
Updated Feb 2013 Various ICE topology compounds that I made for last months. Fully compatible with
SI 2012. After installation they can be found in Context, Interactive and Topology
categories of the Tool tab menu.
Contents: Build Array from Set Node (for Softimage 2012), Array to Edge Set, Array to Polygon Set, Array to Sample Set, Array to Vertex Set, Build Array per Edge, Build Array per Point, Build Array per Polygon, Build Array per Sample, Delete Topology, Disconnect Islands, Get Edge Position, Set Edge Position, Get Polygon Position, Set Polygon Position, Polygon Index to CAV, Vertex Index to CAV, Select Polygons Interactive, Slice to Pieces, To per Edge, To per Point, To per Polygon, To per Sample
The recent updates from the si-community thread linked below include: Greeble, Slice on Cubes, Extract Polygon Island, Split Edge Equally
local backup: ProceduralTopoPack.zip
Re: Procedural Topo Pack
Quite simple. The point is, I want to set the MaterialIDs per polygon "manually", via an array.
You would do this based on some conditions, normally.
Which polygons should have material 1, 2 and 3? If they're based on conditions, it means that you have per polygon booleans, correct? With something like clusters it would look like so:
Thanks, but basically what I want to know is how arrays and sets correlate.
How to I build up an array and put those indices into a, say, polygon set? That's an academic question meant to help me understand how ICE works.
Let's say I have a simple 2x2 grid - 4 polygons. As an example, I'd like to set them like so (to exclude any "rules", thus if-nodes, in the correlation):
Poly MatID
0 3
1 2
2 0
3 1
How would you go about that?
Poly MatID
0 3
1 2
2 0
3 1
Pretty straightforward In this case, array size matches polygon count (polygon set size), if you put a set of indices into the Index port of the Select in Array node, it will select the value of the array by the index of the polygonEugen wrote:Thanks, but basically what I want to know is how arrays and sets correlate.
Poly MatID
0 3
1 2
2 0
3 1
Array to Vertex/Edge/Polygon Set compounds were designed for the array of some indices (i.e. when the size and index order does not match the set size) which you would want to convert to a set
Ha! "Select in Array" is the thing... makes sense.
Somewhat steep learning curve here...
Thanks a lot, iamVXF!!
Eugen wrote:Thanks a lot, iamVXF!!
My nick is so lazy, gosh
The download link is broken?
- Hirazi Blue
If you search for "Procedural Topo Pack" over at rray.de, you should find it in the "local backup" still... ;)
If you can't find there i have it somewhere.
Users browsing this forum: No registered users and 56 guests
