Hi Voltaje, first of all thanks for all the feedback. I updated the compound to 2.3 so download the new one and replace your old one before you do anymore tests.
Quote:
I've got some question, what does Weight_map does?
The weight map should actually be the density map because that is its function. It is applied to the points that the strands are created from and it is a standard filter by weight map compound. See the attached image below about the weight map to height map relationship that should explain everything. If yours in not working like that the the weight map is not applied correctly. If you cant get it to work and you feel you don't need it you can go into the compound and just unplug it, the compound should work fine without it.
Quote:
What's overral color wheight, strand color gradient and strand color weight?
Thanks for pointing this one out my colors setup was not working correctly and I didn't notice it was broken because I was working with shades of green all the time, but I fixed up the nodes and it should work fine in the new compound. See the attached image which should explain the way the color setup works.
Quote:
What kind of things can be connected in On creation
I left that one in there because I used it to plug in things like filter by volume to delete grass when there is objects in the grass field like a big rock or something like that.
I hope this answers all your questions, Let me know if I missed anything.
