PPGLayout Texture Conrtol
homam
Post by homam » 07 Apr 2015, 04:09
Hello,
My plugin property page have a texture control widget added as following:
var obj = CreatePrim("Sphere", "MeshSurface", null, null);
// Creating PPG and adding Texture Control Widget to it
var oPSet=obj.AddProperty("CustomProperty",false,"Demo") ;
oPSet.AddParameter2("inUVs", siString );
var oPPGLayout = oPSet.PPGLayout ;
oPPGLayout.AddItem("inUVs", "Texture Projection", siControlTextureSpace);
InspectObj( oPSet, "", "Check out this layout created from scripting" );
The PPG shows the texture widget successfully however creating new texture projection with the new button or selecting existing texture projection from the dropdown list always returns the following error:
// ERROR : 2003-SetInstanceDataValue - Interface not supported.
SetInstanceDataValue(null, "sphere.Demo.inUVs", "Texture_Projection");
Any clues how to get the texture widget works as expected?
Thanks,
nburtnyk
Re: PPGLayout Texture Conrtol
Post by nburtnyk » 09 Apr 2015, 23:12
We're having the same issue and looking for a solution.
homam
Post by homam » 10 Apr 2015, 03:50
I'm coding my custom widget for now. It is sad reinventing the wheel. :(
I can share it when it is done. It is C# though.
Regards,
luceric
Post by luceric » 10 Apr 2015, 04:35
The error tells you that the parameter must be an object that implement a special API and not just a simple string. It's not possible to create that object with add parameter 2, it must be using one of the shader parameter definition methods, for example spdl
nburtnyk
Post by nburtnyk » 10 Apr 2015, 18:52
Thanks Luc-Eric.
I assume this means it's impossible to have a texture space parameter on a self-installed custom property then?
We have to define the custom property with SPDL instead? #-o
luceric
Post by luceric » 10 Apr 2015, 22:23
right, I don't think that special UV Data selection object is accessible from the SDK. it was created to be automatically managed for shaders.
homam
Post by homam » 12 Apr 2015, 03:56
Since this is not accessible from the SDK why we have siControlTextureSpace exposed :-\
Anyways thanks Luc-Eric for confirming this. That means I'm not totally reinventing the wheel :)
Best Regards,
