GetPrim ("null","mynull")
SetValue oCube = GetPrim ("cube","thecube","mynull")
In JScript, you must terminate each lines with a semi-column, except the comment lines like soGetPrim ("null","mynull")
//Jscript code
GetPrim ("null","mynull");
SetValue oCube = GetPrim ("cube","thecube","mynull");
JS:
VBS:
GetPrim "null","mynull"
Set oCube = GetPrim ("cube","thecube","mynull")
Thank You, worksface wrote:I think you mean:SetValue() is a Softimage command, not a javascript command like set in VBS.Code: Select all
JS: GetPrim ("null","mynull"); oCube = GetPrim ("cube","thecube","mynull"); VBS: GetPrim "null","mynull" Set oCube = GetPrim ("cube","thecube","mynull")
face
for (var p = 1; p<=3; p++){
oNull = GetPrim ("Null", "mynull0")
i = 3.4
oNull.size = 3.0
SetValue (oNull&&".kine.local.posy",2)
