Using Global VB Function anywhere in xsi ?
eternal art
Post by eternal art » 09 May 2013, 13:29
Hello ..
I need a VB function with one Parameter to use it whereaver i want in softimage ( Like Utility Function) , so I simplify what i need in this function just to illustrate my problem ,
function XSILoadPlugin( in_reg )
	in_reg.Author = "ZZZ"
	in_reg.Name = "My ZZZ Commands"
	in_reg.Major = 1
	in_reg.Minor = 0
	in_reg.RegisterCommand "MyGlobalMessage","MyGlobalMessage"
	'RegistrationInsertionPoint - do not remove this line
	XSILoadPlugin = true
End Function
Function MyGlobalMessage_Execute( ZZ )
Logmessage ZZ
End Function
Now I want to use The Same Function In a Button in My Toolbar :
ZZ = "Hi ...."
It's give me an error message :
Type mismatch: 'MyGlobalMessage_Execute' - [line]
Anyhelp or better way to do it is really appreciated .
Re: Using Global VB Function anywhere in xsi ?
Post by rray » 09 May 2013, 13:35
This should work when you remove the _Execute in the button code. It's just an extension so Softimage knows in what function to find the implementation of your command.
eternal art
Post by eternal art » 09 May 2013, 13:52
I tried that :
ZZ = "Hi ...."
MyGlobalMessage ( ZZ )
but still give me an error :
' ERROR : Wrong number of arguments or invalid property assignment: 'MyGlobalMessage ' - [line 2]
Post by rray » 09 May 2013, 13:59
When writing a custom command, you'll have to declare what arguments will get passed to the _Execute handler in the _Init handler. Don't know the specifics right now, it's all in the docs though.
eternal art
Post by eternal art » 09 May 2013, 14:04
I'v tried to search in the doc before i post here with no success , i will try to search again .
I'v attached an example if you can take a look on it .
Thanks in advanced .
MyGlobalMessagePlugin.zip
(620 Bytes) Downloaded 63 times
Post by rray » 09 May 2013, 14:18
It's in the sdk docs, not the normal docs.
There's probably also some example code to copy paste in there.
eternal art
Post by eternal art » 09 May 2013, 14:20
I'v found an example in the doc finally , many thanks rray for your help .
