It is currently 20 Jun 2013, 07:17
Post new topic Reply to topic  [ 52 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6  Next
Author Message
 Post subject: Re: knit the strand
PostPosted: 16 Apr 2012, 18:53
Offline
origin wrote:
sorry that was done some time ago so I dont really remember details.
I think the most annoying thing was nurbs mesh manipulation cause of how lame nurbs in SI are (workaround create nurbs from polymesh and manipulate the source polymesh instead)
as for extruding strands I think I used Fabricios or Guillaume's ice compounds.
I am going to give it a crack this week. Will see what I come up with. Thanks again!
-Nick
Top
 Profile
PostPosted: 16 May 2012, 17:37
Offline
whats the procedure if there is one, to change the pattern to look for example like wool or another type of fabric similar?
thanks
Hidalgo
Top
 Profile
PostPosted: 16 May 2012, 20:49
Offline
thanks
Hidalgo
hi,
there is no built-in procedure for wool. Which wool, btw. It's build on what's called a 'modulo trick'. This method, occasionally, allows the enough pleasant creation of simple patterns, result of this method occasionally reminds to something from real world. For something more complex, I think the best way is manual creation of entire pattern, leaving only variations to ICE, but this isn't a short procedure, anymore.
cheers
Top
 Profile
PostPosted: 16 May 2012, 21:23
Offline
ouch got it, thats bad couse i have some animated cloth that where screaming for your compound :D
only thing is that cage deforming the nurbs (with your pattern) to the polymesh with syflex seems not working, i guess that your methode of creating the cloth from nurbs then exporting it to mesh and add that as a shape key might be the only way.
thanks for the info will try something out.
Hidalgo
Top
 Profile
PostPosted: 17 May 2012, 00:59
Offline
Hidalgo
latest setup is able to render the displacement/bump texture - that's what I would do when it comes to cloth.
Top
 Profile
PostPosted: 24 Apr 2013, 17:29
Offline
Mathaeus wrote:
It appears that you got the strands to form diagonal patterns. How is this done? I can only seem to get them horizontal and vertical.
Top
 Profile
PostPosted: 24 Apr 2013, 17:59
Offline
Btw there is some new compounds available:
http://staplex.ru/?p=589
Top
 Profile
PostPosted: 24 Apr 2013, 20:49
Offline
Chris_TC wrote:
latest one is variation of what's displayed in first picture. Another pics were created by another set of compounds, downloadable on page 3 of this thread, link is bellow this pic.
Generally all of them are variations of early ICE samples by Helge Mathee - strand array is defined in advance, saved as attribute (' strand ratio' or something), then this attribute is used for re-mapping in many ways, including both components of 2d vector, used as input for UV to location node.
Didn't tried stuff from link posted by Bullit - but it looks like much more advanced than mine, from 2009.
Top
 Profile
PostPosted: 24 Apr 2013, 21:00
Offline
Alright, I'll see if I can dig into your compound and find the attributes I need. It may be a few years old, but it's very cool and useful, so thank you!
Top
 Profile
PostPosted: 24 Apr 2013, 21:37
Offline
Of course there's question with diagonal distribution, what to do when array reaches the boundary of NURBS surface, These old compounds creates another emission, in order to fill the corners. Here's a bit newer one which does 'reflection' on boundaries, allowing only one basic emission, more uniform strand distribution as well.
Anyway, if I'll do it again, I think I'll try to use basic pattern, created manually, compound then should be responsible for variations. Should be much easier to figure out by user. But this is only idea, for now.
Top
 Profile
Users browsing this forum: No registered users and 9 guests
Search for:
Jump to:
