I know you can change the colour "Show values" data.
But is there a way to change the size/font of the "Show values"?
I was rather hoping to see more Show Value data instead of a field of green, by reducing that font size. Might be useful too considering 4k monitors are appearing.
4k Monitors and ICE
Re: 4k Monitors and ICE
Go to Preferences > Display > General. Enter a font name under Font (unfortunately you'll need to type in the name of an installed font -- there's no drop-down list) and then you'll be able to set a Font Size.
But to avoid seeing a field of green, I fond it's better to set a %age to display in the Attribute Display settings.
normally I would and do set the display, it's just one of those cases I need to see all the numbers.
Might I suggest the dev's use the "model->text" font name functionality, if possible. Just a nice to have.
Either way, thanks Grahame.
Use a Log Values node?Letterbox wrote:it's just one of those cases I need to see all the numbers.
