zbrush fibermesh
zbrush fibermesh
i use ice strands as a hair from zbrush fibermesh or kristinka, but strands thickness increase as it's far away from world origin, what should i do? it's make me crazy and i can't find anything useful, thank you
Re: zbrush fibermesh
i am still looking for solution, please any idea?
hello,
default is strand size in pixels, so you have impression of increasing the size. In newer SI versions you're able to set absolute size in SI units, instead of pixels. I'd believe this is explained in docs.
For older SI versions, there are few nodes in kH pack for emulating strand size in SI units, "kH strand screen size in SI units", or something like.
actually i was waiting for you to reply ;) , and again thank you for your great help, you were always be my mentor in this hair stuff , and you are always available , i will work on your answer.
actually I have no newer SI version in front of me, otherwise I'd answer directly. According to online docs, should be a special node, called 'set segment size mode'. For zbrush fibermesh or kH stuff, which doesn't simulate automatically, you plug this node in any port of root ICE tree. Seems to be per object context. That is, just a switch for entire ICE point cloud.
Just set the ICE attribute self.shapesizeabsolute to true. Now the strand width will be defined in scene units, not pixels. So, you may need to adjust the strand width to compensate
