Page 1 of 10
Re: PhysX Fluid Simulation in Softimage ICE
Posted: 22 Jan 2012, 23:18
by Tekano
a quick question.. how to tell if physx is enabled on GPU? I often reach a stage of fiddling around where ticking the box on enable gpu has absolutely no effect, where some scenes it does. is there any easy way to tell that gpu is in uses?
Posted: 23 Jan 2012, 08:58
by Mr.Core
You must get this message in script editor after first frame:
// INFO : || CUDA Manager Is Obtained! Created PhysX World!
Posted: 23 Jan 2012, 16:39
by iamVFX
Hirazi Blue wrote:Could you please implement "CUDA accelerated Rigid Bodies" next? =))
The funny thing is - in 2012.5 it's already accelerated
Posted: 23 Jan 2012, 16:44
by Hirazi Blue
I was talking/joking about the well-advertised but apparently not-implemented
"CUDA Accelerated PhysX Rigid Bodies", obviously.
And the Bullet-node only does ICE RBD, or not?
Posted: 23 Jan 2012, 16:49
by iamVFX
Hirazi Blue wrote:I was talking/joking about the well-advertised but apparently not-implemented "CUDA Accelerated PhysX Rigid Bodies", obviously
Ya I get it. But now it's seems actually works. Not for the Phys-eX of course
Posted: 25 Jan 2012, 23:01
by TwinSnakes007
Mr. Core,
If you where able to write a ICE node that can talk to the GPU, then doesnt that mean that GPU accelerated ICE nodes are also possible?
Posted: 25 Jan 2012, 23:13
by Mr.Core
It is possible to implement probably anything that you can do in stand-alone apps, include OpenCL and cuda support and as a result - accelerated nodes. From the ICE node you can just call some functions which are located outside simage
Posted: 26 Jan 2012, 03:42
by gustavoeb
I wonder if guys at Autodesk can do something like that and pass some of the stuff in ICE to the GPU... Guys at Fabric-Engine claim to have done it (and inside a web browser!!!) and they are (for the most part) ex-SI guys with a lot of ICE experience...
Who knows
Posted: 26 Jan 2012, 16:36
by mamali132002
hi mr.core
thanx a lot for ur great work
i have problem for install ur plugin. i have softimage xsi 2012 , i put the px_dlls in C:\Program Files\Autodesk\Softimage 2012\Application\bin and after that i run xsi and in pluginmanager / workgroups i connect application folder to xsi , when i want to open ur test scenes xsi show me an red error message the plugin is not installed .
can u help me please ?
thank u so much
Posted: 27 Jan 2012, 19:36
by origin
You need to connect whole folder structure. That is, put everything that was in zip file in some folder, and connect this folder as workgroup.
Posted: 27 Jan 2012, 20:24
by mamali132002
hi origin , thank u for reply , i do that but i got that error again , see this pic please "
Posted: 27 Jan 2012, 20:38
by Hirazi Blue
Just guessing, but could it be, you haven't got the Microsoft Visual C++ 2010 Redistributable Package (x64) installed?
Posted: 27 Jan 2012, 21:57
by xsisupport
mamali132002 wrote:hi origin , thank u for reply , i do that but i got that error again , see this pic please "
Is there anyone who doesn't have Arnold?
Posted: 27 Jan 2012, 22:44
by mamali132002
no i got that and already installed in my pc .
Posted: 28 Jan 2012, 01:21
by Tekano
Mr.Core wrote:You must get this message in script editor after first frame:
thanks, but I get this message:
' INFO : ICE PHYSX SPH: Succefully created PxWorld!
no mention of cuda , perhaps Ive managed to install the ICE compound but not the dll? I cant see the dll anywhere in the plugins
** EDIT *** UPDATE ***
ok I disabled the previous workgroup, downloaded again the archive, made a new waterfall FX workgroup and now I have 2 versions , one under Px2Si called PhysX simulate SPH and another under ICE PhysX - GigaCoreFX called PhysX simulate Fluid they are both the same compound although the Px2Si version has no execute node only outputs positions.
regardless of this , something seems to have worked - am now getting 60 fps with GPU enabled and reach only 20fps without and when enabled, have the message
' INFO : || CUDA Manager Is Obtained! Created PhysX World!
fantastic! :D
Posted: 28 Jan 2012, 01:33
by rray
Thanks for making this available. Hope i get to try soon.
