It is currently 24 May 2013, 07:20
Post new topic Reply to topic  [ 10 posts ]
 Post subject: change hotkey sets when changing modes
PostPosted: 23 Feb 2012, 22:01
Does anyone know of a script that will change hotkey sets when switching between modes - for
example a different set of hotkeys for animation, modeling, sim, etc... (or if this is even possible)
 Post subject: Re: change hotkey sets when changing modes
PostPosted: 23 Feb 2012, 23:24
I don't think this is currently possible...
(but someone please prove me wrong as it would seem to be a nifty feature)
Broken, not stirred...
PostPosted: 24 Feb 2012, 09:46
as i don't know how to query the construction Mode i'd build myself some fancy buttons.
here's one example that switches to Animation Construction Mode with the Softimage default Keymap:
Jscript
Code:
SetValue("Context.ConstructionMode", 2, null);
SetDefaultKeyMap("Softimage Key Map");
SI 2013 @ WIN7-64
PostPosted: 24 Feb 2012, 10:45
Interesting. I gladly stand corrected on this one. Must look into it some more.
Thanks, caledonian_tartan...
P.S. Isn't it a problem this changes the "default keymap" instead of just switching between keymaps?
PostPosted: 24 Feb 2012, 11:22
it switches instantly AND sets it as a new default, yes.
unfortunately i don't think its possible to only switch it...
but you could create a startup event to override the default keymap at startup if you wish...
SI 2013 @ WIN7-64
PostPosted: 24 Feb 2012, 20:34
Thanks for the suggestion - I'll try this.
PostPosted: 02 May 2012, 22:54
Hi, I use same system (another hotkeys for another modes). It is simple.
Create command in custom plugin and assign hotkey (F1 = model, F2 = animate etc)
In your custom command use this:
Quote:
xsi = Application
xsi.SwitchToolbar( 1 ) #model mode
xsi.SetDefaultKeyMap( "your keymap" )
I also recommend set some visible filter. For example hide nulls, cameras in model, timeslider ... etc.
PostPosted: 13 Jul 2012, 02:35
Quote:
xsi = Application
When I'm trying to run the script it says (Microsoft JScript compilation error) Invalid character
PostPosted: 13 Jul 2012, 04:59
Neat Idea but wouldn't that defeat the purpose? Since soft remembers what it was last set to having the keymap also be the same by default should be the correct behavior no?
PostPosted: 13 Jul 2012, 10:39
This script looks like it's writte in python, you'd have to switch the scripting language
