I did some google searching but without much help. I get this error when trying to import an older dotXSI 3.x file...
' INFO : 4011 - Import/Export .xsi: The dotXSI.dll (NT) or libdotxsi.so (IRIX) is missing or the class is not registered.
So I attempt to run "runonce.bat" as admin only to get this error...
Any way to fix this without a complete reinstall? I also have my environment variables set correctly. I would just try to redownload the 2015 crosswalk installer since that probably contains those files so that a full reinstall wouldn't be necessary but the download on the autodesk website doesn't have the files needed, just plugins for Maya and Max for 2015.
SI 2015 dotXSI import/export and runonce.bat
- minilogoguy18
Re: SI 2015 dotXSI import/export and runonce.bat
Since it is a missing Crosswalk file You could try reinstalling Crosswalk.
https://knowledge.autodesk.com/search-r ... swalk.html
- minilogoguy18
The file is there and the 2015 Crosswalk installer on the Autodesk site only has the Max and Maya plugins, I guess I gotta reinstall SI 2015.
- minilogoguy18
I'm at a loss, tried reinstalling SI 2015, still can't import dotXSI files.
Help???
Help???
It looks like a mismatch of XSI vs crosswalk version but both are 2015 so no idea
If you can upload the file somewhere and pm the link I can try it with my installation (2015) late tonight
But he is trying to import a 3.x file, which uses the old dotXSI.dll.
The second Crosswalk error shouldn't be related.
I have no clue...
I have no clue...
_initializecriticalsectionex errors are usually due to a bad version of visual studio runtime dlls being installed. Like an older one than required. Some freeware programs dump them in the wrong folder and they conflict.
It's weird that you would only get this error for a crosswalk dll. I'm not sure if that's the cause of the issue, what myara says about .xsi 3.x files not using crosswalk sounds right. Y
http://download.autodesk.com/global/doc ... =d28e76414
- minilogoguy18
I was having some issues when installing because I didn't have the right runtimes but I've since fixed that so I don't see how I could be missing other ones.
https://www.dropbox.com/s/lj7tqhcmv63d9j7/root.xsi?dl=0
There is the file. I'm going to try to google around and figure out what those old VS runtime problems I had before and see if I'm missing something. I did do a drive clone recently, maybe something got borked, possibly the VS runtime since I've reinstalled SI after that.
