Talking abou Syflex. Is there a way to easily exchange the cloth mesh? For example if you need to reimport it as the shape has changed, but you want to keep the same settings. Do I need to reassign all the settings manually or can I copy them to the new cloth mesh? The same for the collsion object: Can I exchange it?
Thanks in advance!
Moderator edit: I have split this post from the original discussion you appended it to, as I think it helps your cause
(i.e. getting an answer) if you highlight such new questions in separate threads - HB
Syflex: exchange cloth mesh?
Re: Syflex: exchange cloth mesh?
Just make a compound out of the nodes and apply that compound to your new mesh.
